Tiling Top Row Partially Over Wall? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-05-2008, 03:51 PM   #1
Tiling top row partially over wall?
I am about to tile my shower surround. During the demo I ripped out the surround down to the studs. I'm going to put hardibacker over the studs (redgard over the hardibacker, roofing felt under - right?) and then tile onto the hardibacker with modified thinset.
My question is regarding the small strip of existing drywall around the top rim of the surround. See photo. There is about 4" of existing wall from where the ceiling will be (actually the bottom of a soffit) down to where the hardibacker will go. Is this OK? I am thinking of using 12"x12" wall tiles for the surround, so the top 4" of the top row of tiles will be backed by the existing drywall (it's not gypsum, it is a 1980s moisture-resistant backer material).
Is that OK, or do I have to cut off that 4" strip of wall? It is at the very top of the wall, above the height of the shower head.
rblaine is offline   Reply With Quote
Old 06-05-2008, 04:59 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
REDGARD!!!!!
Felt under
No need for the felt. The RedGard acts as the moisture barrier. You don't need two. Just Hardi directly to the studs and RedGard over, then tile with a GOOD modified thinset.
Just put RedGard directly over the drywall too. You'll be good to go!
Good Luck!
Angus
My Albums
angus242 is offline   Reply With Quote
Old 06-05-2008, 08:00 PM   #3
Registered User
Termite's Avatar
Angus is right, you definately need to seal that cement board after you put it up. RedGuard is popular and will do the trick. Also be sure to mud and tape your joints with thinset and fiberglass mesh tape before waterproofing.
I wouldn't worry about overlapping the tiles over the sheetrock material. If it were lower I'd say don't do it, but up that high you should have no problems.
Wall tiling trowl size help please. Hobb3s Remodeling 5 05-30-2008 07:45 AM
What adhesive to use for tiling wall? sz8 Flooring 4 03-21-2008 05:55 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
