Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-14-2009, 09:10 PM   #1
Tiling a shower enclosure - questions re: hardiebacker & wall prep
Hey all. I'm preparing to tile a bath / shower enclosure for the first time. (No previous experience with tile - except for a tile class) I'd appreciate any advice.
Unfortunately, I've been told different things from different sources about the proper wall prep; now I'm confused. When I took out the old tub and vinyl shower enclosure it left the studs and fiberglas insulation exposed. That's where we start: new tub inserted & exposed studs.
Here's the list (please critique):
  • I should just screw the hardibacker to the studs with corrosion resistant screws, tape and seal the joints, then apply the thinset & tile.
  • I should install a 6 mil plastic sheet vapor barrier over the studs, then the hardibacker, tape & seal, apply thinset, and tile.
  • I should install a 6 mil plastic sheet vapor varrier over the studs, then greenboard, then hardibacker, tape & seal, apply thinset, and tile.
Which is right?
Or are they all wrong?
TIA
Scott
DyerWolf is offline   Reply With Quote
Old 01-14-2009, 10:53 PM   #2
When I did my shower, I used redguard over the hardi. Whether you use plastic under the hardi or a product like redguard over it, you NEED to have a vapor barrier.
No need to use greenboard at all.
Good luck with your project.
ACobra289 is offline   Reply With Quote
Old 01-14-2009, 11:01 PM   #3
Building codes guy, Mod
thekctermite's Avatar
Hang your 1/2" backerboard straight to the wall with backerboard screws. Tape and "mud" the joints and corners with mesh backerboard tape and thinset mixed FROM A BAG...Don't use the pre-mixed stuff.
As for waterproofing, I wouldn't suggest using plastic behind the backerboard. Using a topical waterproofer will keep water from ever penetrating the backer. RegGuard is a very common and popular product for this. You simply paint it on. Works great.
Use modified thinset to hang your tiles. Never never never use mastic in a wet area.
thekctermite is offline   Reply With Quote
Old 01-14-2009, 11:27 PM   #4
K&B Remodeler/Tile Guy
angus242's Avatar
My recommendations for this are:
Insulate with non-faced fiberglass bats.
Use 1/2" DensShield for the walls. It's lighter than most other tile backers and therefore, easier to install.
Hang using alkali-resistant screws.
Tape the seams with an alkali-resistant tape.
Use non-modified thinset over the tape.
Waterproof with Kerdi. Install using non-modified thinset.
Address gap between tub flange and wall with Kerdi-Fix.
Tile with non-modified thinset.
Grout tile. Caulk corners, bottom & top row (if you tile to ceiling)
Seal grout.
Enjoy your tub for a long, long time!
If you don't use Kerdi, at least use RedGard, although it's not my favorite.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 01-15-2009, 07:35 AM   #5
How far down on the flange do you bring the bottom of the lowest tile? Sanded or non-sanded grout?
gma2rjc is offline   Reply With Quote
Old 01-15-2009, 08:50 AM   #6
Unsanded grout.
I'll probably bring the lowest tile down to 1/4" from the edge of the tub and run a bead of sealant.
Old 01-15-2009, 10:52 AM   #7
angus242's Avatar
1/8" gap. Use silicone between first row of tile and tub deck.
Sanded for > 1/8" grout line. Unsanded for < 1/8". 1/8" can be either. Any glass or polished stone tiles should be 1/8" or less grout line and use unsanded so as not to scratch the tiles.
Angus
My Albums
Old 01-15-2009, 11:31 AM   #8
Thanks. Yeah, the pattern I'm using incorporates some glass tile mosaic pieces - which is why we went with the unsanded. I'm already using 1/8 spacers - but had read somewhere that a 1/4 gap was needed between a vinyl tub insert & the tile to allow for expansion / shifting.
I like the idea of doing a 1/8 gap better because it will be a more uniform & seamless look.
Old 01-15-2009, 11:41 AM   #9
angus242's Avatar
To be clear, the TCNA does require a 1/4" gap. I have found that a heavy 1/8" (maybe close to 3/16") will suffice.
When you caulk, you can fill the tub with water and stand inside of it. This will expose the largest gap that occurs. From there, the gap should only contract.
Angus
My Albums
Old 01-15-2009, 11:45 AM   #10
Oh - another question:
I initially planned to use 13" ceramic floor tiles for the shower enclosure which matched up nicely to the glass tile mosaic (13 inch sheets). Unfortunately at the last second, my wife decided she wanted a different look for the adjacent tile; and I couldn't find any 13" tiles with the look she wanted. However, I did find 16 inch tiles she likes - which I planned to cut down to 13 inches to marry up to the glass mosaics.
Is there any problem doing this? I figured I could use the rub stone to clean up any sharp edges for the inner tiles & use the pre-finished edges along the outside edges of the whole enclosure.
The other option would be to cut 3 inch sections of the glass mosaic pieces to match the size of the 16 inch tiles. Either way, I'm looking at a lot of cutting; but what's most important is the finished look of the job.
Any suggestions?
Originally Posted by angus242
When you caulk, you can fill the tub with water and stand inside of it. This will expose the largest gap that occur. From there, the gap should only contract.
Great idea! Thanks!
Old 01-15-2009, 12:10 PM   #11
angus242's Avatar
Well, the decision is yours but I'd be concerned with the cut edges. You should try to keep cuts to the perimeter (corners, ceiling, etc). It's not a safe bet to assume you can mimic the factory edge profile with a rubbing stone. If you don't mind the difference, it can be done. However, will you be OK with the results once completed? That's a bad time to become unhappy about it.
Designing a shower tile layout is not easy. The battle between feasible patters and tile dimensions is a tough one. My suggestion? Decide what's more important to you (ie, the wife!), the pattern or the tile. Now, base the design off which one wins. You may have to change the pattern to fit the tile or buy tile that fits your pattern.
Angus
My Albums
More On This Topic
We finished our drywall. We put our first coat on yesterday, of drywall mud to seal up all the joints and the nail holes. This morning I came in and finished the top layer of the drywall. I used a twelve in knife which makes a nice wide band here, makes... Read More »
Hi! I am Drew Fenn professional home inspector. I am here for Expertvillage.com. Today, we are going to install a shower head and I will show you how and the video is produced by Black Dog Video. You can blackdogvideo.biz on the internet. This is how the... Read More »
Hi, I’m Faith and I’m with Flat Fork Studio, and I’m here to discuss the different kinds of adhesives that you might want to use in doing your tile mosaic project. There’s several different applications. You first need to decide... Read More »
Hi, I’m Faith and I’m here at Flat Fork Studio and I’m here to show you some basic tools that you want to have on hand when preparing to do your mosaic tile project. First we have a caulk gun, Liquid Nails adhesive. This is one type of... Read More »
Hi, I’m Faith, I’m here at Flat Fork Studio and I’m going to show you how to glue your mosaic pieces down to your final piece. And at this point I would use a thinset- a premixed thinset- and it comes from the hardware store already... Read More »
Running wires in a shower wall ? iMisspell Electrical 2 12-03-2008 11:31 AM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 06:06 PM
Removing a (block) wall - questions Genhawk21 Building & Construction 3 09-08-2007 07:26 PM
tiling a shower ceiling.... anedoll Remodeling 1 01-01-2007 08:04 AM
Shower tiling website sharisavage Flooring 1 06-22-2005 09:14 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
