Tiling On Industrial Steel - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-18-2010, 10:07 PM   #1
Tiling on industrial steel
How can you tile on industrial steel? I had a contractor place an opening in my fireplace. He had to frame the opening with industrial steel. Not pretty!! He said you can not paint or tile this material. Is this true? What can I use to tile or paint on this material(industrial steel)?
don57 is offline   Reply With Quote
Old 10-18-2010, 10:18 PM   #2
Rewards Points: 558
What do you mean by industrial steel? do you have any pic's?
epson is offline   Reply With Quote
Old 10-18-2010, 10:19 PM   #3
tiling on industrial steel
No pics. The steel beam used in commercial buildings.
Old 10-18-2010, 10:26 PM   #4
Rewards Points: 558
Ok, what I have seen used was roof decking either laid on top of the steel beam or flush with the steel beam by means of welding steel angles underneath to hold up the decking and then pour about 4Ē of concrete into the decking to make a sub-floor and then lay tile on to it. But because this is your fire place there might be a different installation process.
The Following User Says Thank You to epson For This Useful Post:
don57 (10-18-2010)
New construction on existing steel building burton Building & Construction 6 03-30-2010 03:22 PM
Steel Posts for Screen Porch dobbsj Building & Construction 2 07-15-2009 05:47 PM
Floor bounce joist sistering joehomeowner Building & Construction 24 05-10-2009 01:50 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 03:44 PM
