Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-15-2011, 08:53 AM   #1
Tiling
where do i start tiling a backsplash if there is a window between two wall spaces?
urbaniak57 is offline   Reply With Quote
Old 07-15-2011, 09:26 AM   #2
Super Moderator
Tiling
Lay your tile out on the floor and do some planing ---measure and see what cuts will be at the window and in the corner or open edge. The layout may take a bit of time--but the time is well spent.
Do you math--Mike---
Old 07-15-2011, 01:28 PM   #3
Tileguy
Bud Cline's Avatar
Tiling
How wide is the path of tile that will be under the window?
Is there an apron under the sill as part of the window trim?
Old 07-15-2011, 03:45 PM   #4
Tiling
The window is in the middle of the cabinets and no tile will go under the window the new counter to back splash will go up to the molding. I need to know where to start on the walls on either side of the window. One side goes to the corner and the other side is an open wall with no corner and I want to go to the end of the counter top on that side.
Old 07-15-2011, 05:48 PM   #5
Tileguy
Bud Cline's Avatar
Tiling
Test a layout starting from the window with full tiles and go both directions (from the window) and see where things end-up.
The Following User Says Thank You to Bud Cline For This Useful Post:
urbaniak57 (07-18-2011)
Bathtub/ shower tiling buju Tiling, ceramics, marble 37 08-07-2012 08:03 PM
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 09:37 AM
unstable subfloor for tiling hohadcr Flooring 2 08-27-2010 01:10 AM
First tiling project, need some help DIYD Tiling, ceramics, marble 1 08-06-2009 07:15 AM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 04:44 PM
