Tile Over Concrete Shower Floor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-08-2009, 07:58 PM   #1
diyer in training
Unhappy
Tile over concrete shower floor
Just pulled out shower insert to find big hold around sewer where no concrete was poured. Should I fill in the hole with concrete, or create floor over top ? Thank you so much.
seasidefam is offline   Reply With Quote
Old 11-09-2009, 04:32 AM   #2
Remodeling Contractor
what is it that you are doing after removing this shower base? A new shower? A new floor?
Old 11-09-2009, 04:32 PM   #3
diyer in training
hole in cement floor
thank you - am going to create a shower pan ( the hard way ) - i have decided to fill the hole in ( 16 inches deep ) - partially with gravel and then finish it off with concrete so it is flush with the existing slab. thanks again.
Old 11-09-2009, 04:53 PM   #4
DIY staff
Rewards Points: 7,174
Check this out for ideas,Shower Construction Info (a collection of posts) - Ceramic Tile Advice Forums - John Bridge Ceramic Tile
Old 11-09-2009, 06:49 PM   #5
diyer in training
thank you - great thread....cement is now drying..can hardly wait to start the mud bed ...
Old 11-11-2009, 02:16 PM   #6
Trevski
Remember to make it smooth and level before you put anything ontop. Sounds like a big hole to fill...Good luck buddy.
Trevski is offline   Reply With Quote
Old 09-08-2013, 10:07 AM   #7
www.No-Curb.com
JohnFRWhipple's Avatar
If you live in a multi family home you need to fire stop the hole properly. Just using concrete is not enough of a step.
City inspectors will need to see this work and ensure it is don correctly.
JW
"When it's Perfect. It's good Enough." - John Whipple
JohnFRWhipple is offline   Reply With Quote
Concrete floor over tile Cellomangler Flooring 13 08-25-2012 06:45 PM
Possible to coat or seal a tile floor in a stall shower? Jeff DIY Kitchen & Bath Remodeling 8 08-28-2009 06:51 AM
Replacing floor tile in shower jlweber Kitchen & Bath Remodeling 3 06-29-2009 10:01 AM
Replacing shower drain in concrete floor rjgypsy Plumbing 1 11-30-2008 03:31 AM
Do we have to break the concrete floor for a shower drain? Mechelle Plumbing 41 07-30-2008 08:59 AM
