Tile Grout In Shower - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-19-2009, 03:19 PM   #1
tile grout in shower
my contractor used kerakolor u unsanded grout in the shower the color is mocha when it dried it completely changed colors to a bone color and in some places almost white can anyone tell me why
wvgreg is offline   Reply With Quote
Old 09-19-2009, 04:08 PM   #2
Rewards Points: 5,336
What did he mix it with? Was it water or a latex additive? It's possible it was too loose a mixture or too much water was used to clean the tile.
Ron
Old 09-19-2009, 07:42 PM   #3
he mixed it with water and then i noticed on the 12" tiles the grout was really heavy on them and they used probably ten buckets of water for clean up.
Old 09-19-2009, 09:58 PM   #4
It sounds like the grout was contaminated by too much water, too soon after it was put in.
The extra grout should have been scraped off as part of the installation process through the competant use of a grout float. The slight residue could easily have been removed with a damp sponge after the grout had a chance to set awhile.
If this installation is very recent you should be able to remove the top layer of grout down 1/8" and reapply it again, correctly. An older installation will be more difficult to repair as it can also damage the tile edges unless you're very careful.
Ron
Removing water stains for shower tile grout? acyate General DIY Discussions 2 08-07-2009 06:38 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
Grout question poolecw Flooring 11 10-29-2008 07:32 PM
Can you caulk over grout lines in a tile shower? Greg General DIY Discussions 7 11-20-2006 05:20 PM
