Tile Glue - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 01:12 PM   #1
Rewards Points: 83
Tile glue
I pulled up some old tiles in the basement. They were glued down with a tar like adheasive. I tried a couple different cleaners to clean it up with no success. I was wanting to stain or paint the floor. Any suggestions on cleaners or a process to get it up??
rodsteryz is offline   Reply With Quote
Old 12-30-2011, 01:34 PM   #2
DIY staff
Rewards Points: 7,174
That is called 'cut back'---I doubt if you can ever get that clean enough for paint or concrete stain---
Let's see what the experts say---Mike---
Willie T (12-30-2011)
Old 12-30-2011, 02:16 PM   #3
Old School
Willie T's Avatar
Worst mess I ever tried to get off a floor. I never can get it completely clean, even using Lacquer Thinner.
Willie T
Old 12-30-2011, 02:22 PM   #4
DIY staff
Ceramic tile can be installed over the cut back---Just a thought---
Do be careful if you try solvents---I saw a fellow that had burned himself up pretty good when the solvent fumes reached the pilot on the water heater---He looked like a mummy for a couple of weeks--
Old 12-30-2011, 02:29 PM   #5
Rewards Points: 83
Thanks all. Figures! just my luck this was under the tile. I'm getting used to it, this happens to me all the time Thought about ceramic but i have done quiet a bit of it in the basement already. Yes, I had thought about the fumes also, I was trying some "green" cleaners that were not working. Think I am going to go a different direction with the floor. What about something like this?
http://www.lumberliquidators.com/cat...productId=6964
Old 12-30-2011, 02:41 PM   #6
DIY staff
I'm going to leave that for one of the vinyl experts like Rusty Baker---I don't know if a peal and stick will stick to the old cut back----Mike---
Old 12-30-2011, 03:41 PM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 56
I doubt that would stick to the floor. Why not some loose-lay sheet vinyl? Flexitec makes one that has a realistic wood pattern.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 11:42 PM
Vinyl Tile Underlayment - To Glue or Not to Glue kaypee65 Flooring 9 01-25-2010 08:06 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
YELLOW GLUE and CRUMBLY BRITTLE TILE HELP botal1026 Remodeling 2 07-15-2008 08:23 AM
