Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-11-2011, 01:12 PM   #1
Tighten Garage Door Chain - No Trolly Adjustment
Hi All,
First time on here. I recently bought a house and it came with an older 1/3 hp Beaver garage door opener. The chain has become loose to the point it wont open. It is a tube track unit, with no chain adjustment on the trolly. Through some research it looks like the tension adjustment is on top of the drive. I found the screw adjustment, but it does do anything. I do not have a manual for this unit (nor can I find one) and I am stumped. I also have limited space between the drive and the ceiling of the garage to work.
Does anyone have any idea how to tighten this chain (short of getting a new one)?
Thanks!!
kurdtkobain00 is offline   Reply With Quote
Old 10-11-2011, 01:23 PM   #2
Welcome to the forum! Is there a clamp that needs to be loosened, so that the opener can slide futher out the tube, and then tightened? Depending on how it is suspended, perhaps the opener has shifted closer to the door? Are you sure that there is not a turnbuckle in the chain?
Tags
garage door opener
Detached garage subpanel options? jeffiebean Electrical 6 03-15-2011 09:20 PM
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 02:50 PM
Insulate finished garage ceiling or condition garage? pasichnyk Building & Construction 19 12-06-2010 02:46 AM
Garage Ideas? tripflex General Discussion 13 12-16-2009 08:06 PM
