Thmostat Changed To Outlet ? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-18-2013, 04:25 PM   #1
thmostat changed to outlet ?
I have a thermostat that controls baseboard heating. I have removed the baseboard heaters and would like to use the wiring for the thermostat for an outlet. Is this possible?i hooked it up and everything i plug in doesn't work anymore. too much juice i guess. is there a way i can do this?
bucs12day is offline   Reply With Quote
Old 01-18-2013, 04:34 PM   #2
Rewards Points: 3,816
Do you mean an electrical outlet??
Canarywood1 is online now   Reply With Quote
Old 01-18-2013, 04:37 PM   #3
Rewards Points: 14,294
Well that's one way to burn your house down.
Time to call in a pro.
Most baseboard heat is 220 volt, no nutral, by doing what you did may have made a dead short.
DexterII (01-18-2013)
Old 01-18-2013, 04:45 PM   #4
Rewards Points: 146
I concur. Please do come back, because there are a LOT of maintenance items associated with home ownership, and a lot of good people here to assist you, but this one has the potential of going south on you real quick.
Old 01-18-2013, 04:54 PM   #5
joed's Avatar
Rewards Points: 13,696
The baseboard heaters are operated at 240 volts. When you connected a receptacle and plugged things in you applied 240 volts instead of 120 volts.
To make this function properly you need to change the wiring in your breaker panel so this circuit has a 15 or 20 amp breaker controlling it and is set up for 120 volts.
The Following User Says Thank You to joed For This Useful Post:
bucs12day (01-18-2013)
Old 01-18-2013, 04:55 PM   #6
but is there a way to use the wiring for an outlet? or should i just cap the box
Old 01-18-2013, 05:00 PM   #7
thanks joed thats what i thought
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Switched outlet series Overkll Electrical 4 12-07-2010 07:38 AM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
washer/dryer frying my outlet dontwannadiy Electrical 15 07-27-2009 11:52 PM
Help Help richie02 Electrical 7 06-17-2008 08:42 AM
