I bought my house last November, a 3 bed/1 bath with a big unfinished basement. I live in the attic with two tenants renting from me, I recently put in a second bathroom in the basement, and I want to move down there next to it so I can rent out the attic for even more moneydollars. At some point I'll be finishing the whole basement and adding a proper bedroom, but in the meantime this would help finance it. I was gonna make temporary walls out of office cubicles, boxes full of blankets, hanging more blankets, etc etc. A few concerns:
Will a space heater be viable for making it through a Minnesota winter? Will it be dangerous to have it running for hours at a time? I wouldn't leave it on when I wasn't home at least.
How can I verify that there's no mold etc? I've heard the storebought tests aren't really worth much. I've got a dehumidifier running 24/7 and the moisture's still 50% right now. There's some stains on the walls, but I have never personally seen any water come in during my time here, and it smells normal. I've hung out downstairs for extended periods already with no consequences. Just wanna be sure. I think I might repaint the walls with a new coat of white moisture repellent paint, which would also make them not look gross, but I don't wanna cover up a problem if there is one.
Anything else I should be worried about? Is this a terrible Cosmo Kramer idea?
A vented space heater no where near combustibles is a safe as a furnace. Homes were heated for many years that way. MN and BTU's required I have no clue.
This is the only response I've read that mentions vented space heater.
If it is non vented you won't be needing a egress window nor will any of the other occupants. Body bags will be required.
If you want to heat it with electricity long-term, why not get some 'permanent' baseboard heaters and a thermostat and wire them in temporarily but safely?
Is there a furnace in the basement now that is heating the rest of the house? If so it would be not too difficult to tap into that.
If the walls are concrete or block, a couple of coats of flat white wall and floor paint will brighten the basement up considerably.
50% is fine if you can keep it there. The dehumidifier will help heat the basement too.
Do you have enough AC outlets for what you want to do?
I've got a boiler just a couple yards from where I was going to be staying. I imagine you can't really change things around as easily as with a furnace... Never looked into baseboard heaters before. There's tons of outlets downstairs, so no worries there. What makes this superior to using space heaters?
I hope this thread is a joke. I won't even bother to ask if the OP has considered permits for the work he plans to do, or if his current "boarding house" arrangement is even legal.
Humans tend to be most comfortable at around 40-60% Relative Humidity (RH). Your current measurement of 50% RH is perfect -- no need to try to force it any lower.
While mold can affect people differently (think pollen allergies, etc.) mold spores are common in the air and most folks are unaware that they breathe in mold spore all the time. Mold is rarely any sort of significant health concern except for extremely asthmatic, allergic, or immuno-compromised. If you SEE visible mold growth -- get rid of it as well as (important) the underlying source of moisture which allowed the mold to grow. If you do not see significant mold growth, don't even worry about it.
Please make sure you have a working smoke / co alarm where you are planning on sleeping.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
