Thermostat Issue - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-26-2011, 01:23 AM   #1
Thermostat issue
I have just moved into a new house and noticed the thermostat for the living room baseboard heater was broken. I bought a new digital thermostat it said the wires were not polarized so either wire would work. After hooking it up I threw the breaker and the thermostat blew up. I then tested the line and it showed 240 and drawin like 1.4 watts. Could the heater be bad or wired incorrectly?
Dconklin80 is offline   Reply With Quote
Old 01-26-2011, 07:11 AM   #2
Rewards Points: 6,652
Nope, no way. I want to see a picture of the thermostat, and the wires from the baseboard, because now you peaked my interest.
Old 01-26-2011, 07:42 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,186
Was the replacement t-stat line voltage (240 volts) or a low voltage (24 volts)? If you hooked up a low volage unit 20 240, it would self destruct.
Coastal South Carolina
Old 01-26-2011, 08:54 AM   #4
Rewards Points: 5,336
You hooked up the wrong type thermostat to the electric baseboard. Did you make a note of the thermostat you removed? Did you notice that the wires connecting them were not low voltage wires?
I would stay away from repairing anything in the electric area until you have a more thorough understanding. Start by picking up one of those Popular Science or Black and Decker books.
Your current understanding of the subject will get you killed or you'll burn down the house.
Ron
Old 01-26-2011, 01:44 PM   #5
I did make a note of the thermostat I took off. In fact after the first blew i went out out and bought an exacct to the one that was on there to have the exact thing happen. This isnt my first time doing this I posted because this was odd to me. Yes electricity is not my first pick to do but I know enough to be dangerous. Ill post some pics for the fella thats interested. The thermostat I had bought would accept no more then 16.7 watts and would go as high as 240 v
Old 01-26-2011, 02:16 PM   #6
If both thermostats,"Blew", you have a dead short somewhere. Find that first.
Ron
Old 01-26-2011, 03:18 PM   #7
Thanks for the info ill look into that.
Old 01-26-2011, 03:22 PM   #8
A "Handy Husband"
rjniles's Avatar
Tell us what you bought- brand and model number.
Old 01-26-2011, 03:22 PM   #9
Also isnt a little strange when these blow its not tripping a breaker?
Old 01-26-2011, 03:24 PM   #10
Rj im headed to pickup some paint ans when I get back to the house ill post all that info I know its a honeywell. Also will post some pics of baseboard heater and how its wired.
Old 01-26-2011, 03:50 PM   #11
It might not be wired correctly in the box, or the wrong breaker is being used.
Is it wired to a double pole breaker?
Ron
Old 01-26-2011, 04:56 PM   #12
It is a double pole breaker.
Old 01-26-2011, 04:59 PM   #13
Theses are the pics wall baseboard and the first thermostat that blew
Thermostat issue-forumrunner_20110126_145625.jpg   Thermostat issue-forumrunner_20110126_145646.jpg   Thermostat issue-forumrunner_20110126_145714.jpg   Thermostat issue-forumrunner_20110126_145731.jpg   Thermostat issue-forumrunner_20110126_145749.jpg
Old 01-26-2011, 06:02 PM   #14
This thermostat is a dual voltage unit. It has a switch to change from 110 to 220.
Was the switch placed on the correct voltage?
Ron
Old 01-26-2011, 06:02 PM   #15
A "Handy Husband"
rjniles's Avatar
Looking at the picture of the box that mounts the t-stat, it looks like the wires are not secured with a cable clamp and the insulated wires are rubbing on the metal box. It looks like the one on the right has some burn marks. The sheath of the cables should extend into the box and be secured and the conductors protected fro the metal edge of the box.
Furance & AC Issue Lobley HVAC 6 09-12-2009 10:30 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 10:07 PM
ac/furnace runs whatever thermostat settign donbohn HVAC 1 06-20-2009 05:42 AM
New Thermostat issues when cooling guimond777 HVAC 2 05-04-2009 10:46 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
