Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-13-2011, 01:14 PM   #1
thermostat contolled attic fans
do thermostat contolled attic fans really work? worth the money? to lower A/C costs and to keep even temperature to keep heat expansion/contraaction at minimum to avoid noisy popping sounds?
Cohiba is offline   Reply With Quote
Old 05-13-2011, 01:21 PM   #2
Household Handyman
From what I have read and experienced with these type fans: They do work to move air through the attic area if the attic area is configured properly. They DO NOT work with ridge vents, understandably. IF you have both soffit venting and gable vents, they do not work efficiently as they will draw air from the source of least resistance. I have come across this situation and shown the homeowner the inefficiency of this. Blocking off the gable vents improved air flow via the soffit venting. One thing I will say: Most of these units have no provisions to shut off power IF the motor locks up, which is common with these. There have been a number of home fires in my area which were ruled as caused by these attic fan motors "locking up", then overheating and starting the fire. When I install, or replace a motor on, these I also add an inline fuse just for the fan motor. Depending on a circuit breaker, which may/probably has, other applications just is not safe to me.
Old 05-13-2011, 01:44 PM   #3
i only have soffit vents around the house - anything you would recommens. the solar ones, whirly bird, etc.?
Old 05-14-2011, 12:48 PM   #4
Ridge vent is all you need.
+1 on the house fires , I would never use an attic vent , passive is the way to go.
High Gear is offline   Reply With Quote
The Following User Says Thank You to High Gear For This Useful Post:
Cohiba (05-14-2011)
Old 05-14-2011, 01:20 PM   #5
Don't mean to hijack but rather spur the discussion
Thread is of interest to me due to a room addition project nearing. 16x26 master bedroom with 4/12 tiled roof. SoCal where summer hits 90 degree plus easy - winter nights coldest is usually 40 or so.
Planning currently for two O'Hanlin vents centered high On either side of the ridge and a solar powered fan exhausting through gable end vent. No eave/soffit vents allowed due to fire zone codes. Insulation in 2x6 walls of R20 or more and ceiling with R40 or so. HVAC via mini split heat pump / AC unit.
CA title-24 compliance needed.
Thoughts / comments?
____________
Vince
Old 05-14-2011, 01:47 PM   #6
What about solar fan ? Or whirlybird birds? Or other?
Old 05-14-2011, 01:53 PM   #7
No moving parts , ridge vent is pretty much foolproof.
Cohiba (05-14-2011)
Old 05-14-2011, 01:57 PM   #8
My roof is flat with soffits all around
Old 05-14-2011, 02:13 PM   #9
If flat roof, what is the space and size that needs ventilation? If flat sounds like there won't be much natural air movement via convection..
Where are you located?
I am planning for the solar all purpose ventilator from:
http://www.ussunlight.com/products/solar-attic-fans
Other models and info on their website.
Old 05-14-2011, 02:16 PM   #10
Live in warm climate, over 100 degrees in summer. Trying to both lower ac expense and quiet heat expansion and contractio noise in attic. Familiar with this?
Old 05-14-2011, 02:35 PM   #11
Very familier with ac expense but never had noises from heat expansion and contraction - have lived in hot southern climes most all my life and through several houses. I can see where flat roof can get very hot due to no nature convenction air flow - hot air rises, but if flat you have no where for it to go. So some sort of powered ventilator may well be a good thing. I like the solar powered fan units.
More details of your roof construction, insulation, and attic space may help folks to help you better.
Old 05-14-2011, 10:31 PM   #12
CDH
I installed a power ventilation attic fan and it keeps my attic at around 100 degrees in the heat of the Florida summer, had 3 off ridge vents and unless there was a pretty good wind blowing you could feel very little air coming out of them and attic temps got up to around 130+, I have not closed off my off ridge vents and my attic stays 30 degrees cooler so I believe they do as advertised.
CDH is offline   Reply With Quote
Old 05-15-2011, 12:43 PM   #13
I have 5 "pancake style" power vent fans. All are "Thermal Overload Protected"---Why would someone need additional protection with inline fuse.
Also--what size fuse would you recommend?
Giles is offline   Reply With Quote
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 12:46 PM
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 06:06 AM
thermostat and humidity controls for electric attic fans lowlysubaruguy Roofing/Siding 2 09-25-2008 08:32 AM
