Is There A Weight Limit In A Garden Window? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-15-2009, 12:30 PM   #1
Is there a weight limit in a Garden Window?
I have a 48 inch wide by 17 inches deep garden window and want to put granite tile on the inside. I estimate the combined weight of tile, board and cement to be 50 to 60 lb. This excludes any plants or other stuff we may put in it once it is finished. Is there a guideline as to how much weight one can put in these windows? My conrtractor says no problem, but I would like to be sure.
rwith is offline   Reply With Quote
Old 05-15-2009, 12:51 PM   #2
Rewards Points: 600
That seems like an awful lot of weight. Did you try calling the manufacturer?
gma2rjc is online now   Reply With Quote
Old 05-15-2009, 01:03 PM   #3
I weighed a piece of tile, scaled it to the window area and doubled the result to account for board and cement. I have not called the window manufacturer, but will see if I can get information from them.
Old 05-15-2009, 02:43 PM   #4
Rewards Points: 600
I suppose it depends on how well the window was installed also. Did the contractor you mentioned install the window?
Old 05-15-2009, 03:41 PM   #5
Yes, but he did not brace it
Old 05-15-2009, 04:02 PM   #6
Rewards Points: 600
It might help to have your contractor write a description of how he installed the window and what materials he used. When you call the manufacturer, you can describe what's been done.
Sources for kitchen garden window? Eric in NC General DIY Discussions 11 06-06-2014 09:03 PM
garden window question viviank General DIY Discussions 4 05-28-2009 07:10 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
Sealing garden window properly bluefitness Remodeling 7 12-01-2008 10:10 PM
Insulating window weight pockets sergv General DIY Discussions 2 11-02-2008 05:34 PM
