Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-11-2009, 01:43 AM   #1
Is there a simple way to bend 10' alluminum,without a brake?
Whats the easiest way to bend aluminum trim into a simple 90 degree angle. ???? (THIS) piece will be hidden so it CAN be a little ugly.
Was thinking of clamping between 2 2X4's and bend top part. Then also thought about clamping 2 angle irons together, BUT the inside of angle is round. Anything heavy enough to take the racket with a true right angle inside angle?/
4just1don is offline   Reply With Quote
Old 05-11-2009, 06:48 AM   #2
Angel iron, as you suggested, since rough is not an issue. Any finished lumber has sharp corners, if it does not need to be a sharp bend, 2x4 works. Use a rubbber or plastic hammer to help urge it into shape. Those tools are less likely to stretch the metal.
Old 05-11-2009, 07:49 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Take a section of plywood, and clamp it down stationary. Figure out the two lengths of the aluminum sides, to locate where the bend will be. Mark this out on the plywood. You will have a drawn out "L" shape pattern.
Using your skill saw, on the clamped down plywood, do two straight cuts into it, to form the marked out "L" shape. You are creating a "form template".
Once the cuts are made, and you check the measured cuts, etc - Get a helper to hold the plywood in place (vertically), while you run the length of the aluminum thru the plywood "template".
The aluminum will form to the 90 degree angle cut-out, and you should have what you need.
This method is good for installing aluminum in non-visible areas, such as substrate flashing.
Good Luck on the project.
- Build Well -
Old 05-11-2009, 11:15 AM   #4
Old School
Willie T's Avatar
That sounds neat. I've never tried that.
Like this.....?
Is there a simple way to bend 10' alluminum,without  a brake?-plywood-shaper-form.jpg
Willie T
Old 05-11-2009, 12:03 PM   #5
Like this.....?
Exactly.
- Build Well -
Old 05-11-2009, 03:33 PM   #6
Household Handyman
AtlanticWBConst.- -Thank You for sharing that neat trick. I have need to bend lightweight aluminum flashing often and I am going to keep that trick in mind. Thanks, David
Old 05-12-2009, 07:11 AM   #7
Your very welcome David.
- Build Well -
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 11:48 AM
simple closet lighting theboss Electrical 8 02-16-2009 09:56 PM
Conduit Bend Calculation Help johnny5 Electrical 9 01-20-2009 11:35 PM
Brake Light sd04 Electrical 11 07-13-2008 06:08 PM
2005 Dodge brake wiring schematic dwallace Automotive Repairs 2 09-10-2007 08:48 AM
