-   -   Is there a simple way to bend 10' alluminum,without a brake? (http://www.diychatroom.com/f2/there-simple-way-bend-10-alluminum-without-brake-44254/)
4just1don 05-11-2009 12:43 AM
Whats the easiest way to bend aluminum trim into a simple 90 degree angle. ???? (THIS) piece will be hidden so it CAN be a little ugly.
Was thinking of clamping between 2 2X4's and bend top part. Then also thought about clamping 2 angle irons together, BUT the inside of angle is round. Anything heavy enough to take the racket with a true right angle inside angle?/
Just Bill 05-11-2009 05:48 AM
Angel iron, as you suggested, since rough is not an issue. Any finished lumber has sharp corners, if it does not need to be a sharp bend, 2x4 works. Use a rubbber or plastic hammer to help urge it into shape. Those tools are less likely to stretch the metal.
AtlanticWBConst. 05-11-2009 06:49 AM
Take a section of plywood, and clamp it down stationary. Figure out the two lengths of the aluminum sides, to locate where the bend will be. Mark this out on the plywood. You will have a drawn out "L" shape pattern.
Using your skill saw, on the clamped down plywood, do two straight cuts into it, to form the marked out "L" shape. You are creating a "form template".
Once the cuts are made, and you check the measured cuts, etc - Get a helper to hold the plywood in place (vertically), while you run the length of the aluminum thru the plywood "template".
The aluminum will form to the 90 degree angle cut-out, and you should have what you need.
This method is good for installing aluminum in non-visible areas, such as substrate flashing.
Good Luck on the project.
Willie T 05-11-2009 10:15 AM
1 Attachment(s)
That sounds neat. I've never tried that.
Like this.....?
AtlanticWBConst. 05-11-2009 11:03 AM
Like this.....?
Exactly.
Thurman 05-11-2009 02:33 PM
AtlanticWBConst.- -Thank You for sharing that neat trick. I have need to bend lightweight aluminum flashing often and I am going to keep that trick in mind. :thumbup: Thanks, David
AtlanticWBConst. 05-12-2009 06:11 AM
Your very welcome David.
