Temporary Internal Plexiglass - Weatherproof Weatherproofing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-16-2014, 12:13 AM   #1
Rewards Points: 18
Temporary internal plexiglass - weatherproof weatherproofing
Hi. First time poster here, so please be easy on me.
I have a window deep in flat drywall wall square with no molding around the frame, in a condo. Would like to slap some kind of -temporary- plexiglass over the hole to keep the draft out. The window hole is 4 feet by 4 feet.
What would you suggest for the hardware to be able to snap it on and have it weatherproof- airtight for the winter, then be able to remove it easily (with no tools) in the spring?
I was thinking of, I don't know what they are called- those spring rocker fastener thingies to hold the plexiglass close to the wall, but they are kind of ugly.
Any ideas would be appreciated.
Last edited by danseeksideas; 11-16-2014 at 12:17 AM. Reason: ETA - more descriptive
danseeksideas is offline   Reply With Quote
Old 11-16-2014, 12:29 AM   #2
Rewards Points: 18
Another idea I had was to use four temporary fasteners like square 'cups'. One in each corner. And then the plexiglass frame would have the corresponding stubs to match the 'cups' - that would enable me to drop it in.
Of course the plexiglass would have weatherstripping tape all around it- to keep it airtight.
I can't seem to find these cup-like fasteners, or the stubs needed for the frame to match with them. Do they exist?
Old 11-16-2014, 07:35 AM   #3
Rewards Points: 802
Slide doors for cabinets have channels that allows the doors to be removed. May be you can use the channels and frame weatherized, so the plexi can be press fitted.
carpdad is offline   Reply With Quote
Old 11-16-2014, 08:38 AM   #4
Rewards Points: 236
use plastic window film. it works well.
Fix'n it is offline   Reply With Quote
The Following 2 Users Say Thank You to Fix'n it For This Useful Post:
Bondo (11-16-2014), joecaption (11-16-2014)
Old 11-16-2014, 09:55 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,636
Ayuh,.... No doubt a much better, simpler answer to the problem,....
Old 11-16-2014, 11:39 AM   #6
Can you post a picture.?
How much do you plan to spend.?
ron45 is offline   Reply With Quote
Old 11-16-2014, 12:01 PM   #7
Rewards Points: 18
Lightbulb
Thank you for your response. sure. It's just a hole in the wall, so to speak.... I want to put something in on this side of the curtain (the inside part).
I'm thinking maybe up to $100.00.
Old 11-16-2014, 12:05 PM   #8
Rewards Points: 18
Plastic I've used before. It works pretty good.
The only drawback is that it 'bubbles'. The outside air is constantly trying to get in once it's sealed, so it constantly looks like a blister that wants to pop for the whole winter. This is probably because it's such a big window- 4' x 4'. On smaller windows, the bubbling part is not so noticeable.
Old 11-16-2014, 12:07 PM   #9
Rewards Points: 18
That sounds great. They can make the slide and the fit airtight? Is there a company on the internet where I can send my dimensions to- for them to make the frame and the slides?
Old 11-16-2014, 12:46 PM   #10
Rewards Points: 18
A little more information...
Here is a side and top view of the sill by the window. There is six inches space there before the curtain - to the inside...
Thanks.
Old 11-16-2014, 02:09 PM   #11
Bondo's Avatar
Ayuh,.... What's behind the curtain,..??
Why not seal up the original window, insteada 6" away from it,..??
The Following User Says Thank You to Bondo For This Useful Post:
danseeksideas (11-17-2014)
Old 11-16-2014, 02:23 PM   #12
Rewards Points: 18
I'm not sure what you mean. There's two cheap aluminum frame sliding windows behind the curtain, split vertically. Very drafty- both of them. To seal one up, you mean?
Old 11-16-2014, 05:14 PM   #13
Rewards Points: 18
Sorry. My previous post was a bit confusing. You mean like caulk up the window?
It's actually a good, quick, cheap idea. I would just have to NOT put the caulk in the cracks where the soft felt-type material is... so I don't ruin it (like it really works/matters or something).
Is there a better thing for this than caulk? There's that spray gook that looks like styrofoam when it's dry. Just not sure if it would stain the white paint on the aluminum after it's removed.... being orange or yellow in colour.
Old 11-16-2014, 07:37 PM   #14
Rewards Points: 236
there is caulk, that is not permanent. it pulls off when you want. use that to seal the leaks (the reason the window film bubbles). then use window film....
then, next summer, get a new window.
The Following User Says Thank You to Fix'n it For This Useful Post:
Old 11-16-2014, 08:42 PM   #15
The Following User Says Thank You to ron45 For This Useful Post:
Where to put temporary power phil2 Building & Construction 18 05-12-2014 10:57 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
