Temperature Requirement For MIXING (not Applying) Thinset - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-09-2011, 11:47 PM   #1
Temperature requirement for MIXING (not applying) thinset
Hi everyone! - Is there any minimum temperature requirement for MIXING (not applying) modified/unmodified thinset? Is it OK to mix thinset outdoor where temperature is zero C then apply it indoor where temperature is 23C? Thanks for your responses.
gzenar0sa is offline   Reply With Quote
Old 12-10-2011, 04:07 AM   #2
DIY staff
Rewards Points: 7,174
Are you talking about mixing mud out doors in the winter?
No problem---just bring the mud inside before it freezes----add some details to your question,please---
Old 12-10-2011, 05:28 AM   #3
Rewards Points: 2,240
Just to add something -
I ran into an "Old" tile-setter a number of years ago.
I got to work on the same houses he was working.
We discussed tile work a lot.
It was winter and he was mixing thinset in the garage.
He said, basically, the same thing that "oh'mike" said.
Also, he said don't use "Hot" water - use cool water (clean)!
something concerning the chemical reaction that goes on when you add
the water to the thinset.
rossfingal
rossfingal is offline   Reply With Quote
Old 12-10-2011, 05:32 AM   #4
DIY staff
Accidentally mixing the mud with warm or hot water is a huge mistake---Been there--never want to go there again!!!!
rossfingal (12-10-2011)
Old 12-10-2011, 11:39 AM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Just curious. Why? What happens?
Old 12-10-2011, 11:45 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The products should be kept with a temperature of mid-range, maybe 55 to 90 degrees Fahrenheit. Tile installation must be kept above 55 degrees Fahrenheit. Mixing the thinset in extreme temperatures probably isn't the best idea. Cold water mixing will slightly slow an other wise normal process of curing. Warm or hot water mixing will accelerate the curing process and in some cases render the product unusable in a matter of minutes.
The Following 4 Users Say Thank You to Bud Cline For This Useful Post:
Big Stud (12-10-2011), Blondesense (12-10-2011), oh'mike (12-10-2011), rossfingal (12-10-2011)
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
sweating double pane windows etch Windows and Doors 6 10-31-2011 09:30 PM
Condensation amyevans Windows and Doors 6 10-21-2011 10:11 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
