Teleposts Thru Heating Duct - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-07-2010, 08:10 PM   #1
teleposts thru heating duct
I am doing a kitchen reno and I need to install a telepost in the basement so i can remove a bearing wall. The problem is that the telepost needs to be placed in the center of the main heating duct(square one). Can I cut a round hole in the duct and so the post can pass thru? I would put a round sleeve in the duct to seal of the hole so I don't loose my air flow is this aloud and will it meet code.
suks2beme is offline   Reply With Quote
Old 01-08-2010, 06:42 AM   #2
Rewards Points: 5,336
It would help if you were more detailed about the structural issue, as it may not require adding a post. Maybe post a picture of the kitchen wall and the basement area the pole would go.
How did you purpose to set the post on the floor?
Putting a pole through a duct would not be the way to do it.
Ron
Old 01-08-2010, 07:44 AM   #3
i'm thinkihg no to all your questions
Old 01-08-2010, 07:52 AM   #4
Rewards Points: 6,652
Answer would be no. Did the engineer state that that is the place that it needed to go? If so, you will have to move the heating duct over.
Old 01-08-2010, 09:54 AM   #5
You need to be able to access the top of the post to secure it in place
So the duct need to be moved or a new plan
Plywood heating duct ? willem HVAC 10 09-29-2010 07:09 PM
Capping un-needed heating duct? paredown HVAC 0 07-02-2009 06:26 PM
running gas line near or under heating duct NowItsShowtime Plumbing 1 03-26-2009 01:18 PM
Oh no...I dropped a piece of MDF into my heating duct. J187 Building & Construction 6 03-25-2009 07:58 AM
Is it alright for insulation to touch a heating duct? vetting Building & Construction 5 02-28-2009 02:46 PM
