Telephone Distribution Question/ - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-01-2009, 12:10 AM   #1
Telephone distribution question/
I want to put all the phone lines into one are in a distribution block. I want the easiest way to do it. I don't want to do a 66 or 110 block but want something that looks neat and makes my job a little easier. What do you recommend?
I would also like to distribute cable to several rooms. Thanks.
ingeborgdot is offline   Reply With Quote
Old 03-01-2009, 06:51 AM   #2
Not sure what you are looking for. A single phone lines requires two wires, each additional linerequires two wires. Phone lines used to come into the house as a 4-wire cable, not there are multiple pair cables or fiber-optic cable. They usually have a junction box on the outside of the house and are then routed to where they are needed from there. The cable can be daisey chained from location to location or individual cables run to each location. Running cable in new construction is easy, in existing construction it can be difficult.
Old 03-01-2009, 07:08 AM   #3
Electrician
Buy a cabinet and install a 66 or a 110 block inside of it. Only way I would do it.
chris75 is offline   Reply With Quote
Old 03-01-2009, 10:01 AM   #4
Something like this?
http://www.fruitridgetools.com/store...id=8171&dfid=1
jerryh3 is offline   Reply With Quote
Old 03-01-2009, 12:19 PM   #5
I used one of these for the phone $2 at Radio shack. We only have 2 phones in use in the house. We may actually shut it off this year & use cell phones only
I connected all of one side together, then the other the same way
Then I brought in each line & connected to the block. I used some leftover 6 pair CAT3 cable I had. If I ever need the wiring for something else it's there
Old 03-01-2009, 09:45 PM   #6
Rewards Points: 264
Some good information here...
http://www.swhowto.com/
7echo is offline   Reply With Quote
Old 03-02-2009, 04:13 PM   #7
I want to use cat5e for future, if there is any future.
Old 03-11-2009, 09:31 PM   #8
Krone blocks are the way to go
Use a block called a krone block. You will need a special tool for this, but they are much neeter than a 66 block. a good installation and some neet and creative stapeling can go a long way. Beware of the type of block that scuba dave is recomending. I have seen many of thesego bad when there is moisture in the basement.
doin my best is offline   Reply With Quote
Old 03-11-2009, 10:00 PM   #9
Here is what I went with.
http://www.openhousesystem.com/productImages/BH619.jpg
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
New service Question Onytay Electrical 1 10-24-2007 05:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
