Telagraph Poles, How On Earth Do I Put Them In...?? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Closed Thread
Old 12-17-2009, 10:13 PM   #16
Too Short? Cut it Again!
Originally Posted by shabba1985 View Post
wow that deep?
No kidding? London claims a frost line to 42 inches? I live on the American prairie in about two months the actual temp will be about 10 on good days with wind chills taking us down to as low as -30 or so. Our soil does not frost more than a few inches and the freeze depth of 42 inches is hopefully impossible. I also know London well. Just where within the city are you building this pole shed?
You would not be trying to waste the time of the people on this site would you?
user1007 is offline
Old 12-17-2009, 10:21 PM   #17
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
if you have 30 foot poles and you are going to cut them in half and you are going to have 9 foot sidewalls, why bother cutting them again. Just plant about 5 to 5 1/2 feet in the ground so you have enough to cut off the tops inline with each other once you get them set.
deeper is always better.
depending on the soil type, you might really want to consider a concrete footer to support the posts.
to hold the posts up, once you get the corner posts set, you can tie each subsequent pole to the next one for side to side support and will only need to brace it for in and outward alignment.
nap is offline
Old 12-18-2009, 09:15 AM   #18
waste peoples time??? I don't know about that... If you would really like to know my friend I am building this in a large adventure playground for kids, here it will be used for storage and teaching them how to do certain aspects of wood work amongst other stuff,
I should add... as we have no funding, we cannot use heavy machinery, but we have alot of man power/children power even ... so that is why i am cringing when i see 4 foot plus as we can not afford to bring in tools, but I am sure our digging will be worth it in the end.
shabba1985 is offline
Old 12-18-2009, 10:27 AM   #19
Master General ReEngineer
Bondo's Avatar
Rewards Points: 354
Ayuh,... I donno what it's like on your side of the pond,...
I can rent a posthole auger for about $100. a day, or Less....
It's a 1 man unit, towed behind your car...
Bondo is offline
Old 12-18-2009, 10:42 AM   #20
nap
You talking to me?
nap's Avatar
do some research on the Egyptians and the Amish. They used methods that will aid your building. With enough manpower, you can build...
well, you can build a pyramid 480 feet tall.
there are methods for planting tall timbers without power assistance and they aren't actually as difficult as you may imagine. Just use caution.
nap is offline
Old 12-18-2009, 11:11 AM   #21
Civil Engineer
Rewards Points: 4,522
First of all, I think the OPS is in London Ontario, not London England. Second, the assumption that all you have to do is get the pole below frost line to be stable is COMPLETELY WRONG. The poles will be subject to lateral loads due to wind load on the structure. The actual depth required is a function of the loading on the structure, the size of the poles, the soil conditions, and the connection details.
Constructing a facility such as you have to be used by children and adults based on uninformed advice from a DIY group is, in my opinion, a truly bad idea. You need professional assistance from an engineer who can evaluate the loads on your building, and determine the required burial depth and bracing required. If you cannot afford professional assistance, you may need to reconsider the entire project.
Daniel Holzman is offline
Old 12-18-2009, 12:18 PM   #22
thats true it parts, but... c'mon needing a structural engineer for a wooden shed on mud/grassland??... I am sure he would just say "oh, yes we need to dig 4 feet" reason being is: we don't have a heavy roof (plastic sheets), and most of it is just common sense, stuff I already know... but just double checking with you guys to see if I am on the right track, which I appear to be.
Old 12-18-2009, 12:50 PM   #23
Actually the IP tracks to the UK - so London England
This is beyond the scope of a DIY project given its use
For liability & to protect the children that will be in this structure you do need Pro help
Not saying that you can't DIY, but its not a homeowner building a shed in his back yard
Thank you
Scuba_Dave is offline
Closed Thread
Tags
foundation , poles , telegraph , wood
Odd subject: Bumpers for utility poles? jaes General DIY Discussions 7 08-19-2008 02:03 PM
New stove switch doesn't have place for earth wire warrickvdb Electrical 1 05-08-2008 01:18 PM
Polish flat - No earth! Sosh Electrical 3 07-10-2007 12:49 PM
3 phase anyone? Tomkah Electrical 3 01-05-2007 06:18 PM
