Technical Term For The OPPOSITE Of A STRUCTURAL WALL? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 06:55 PM   #1
[SOLVED] Technical term for the OPPOSITE of a STRUCTURAL WALL?
I am writing a formal letter to the owner of the home sharing common walls with us. To sound as professional as possible, I would like to use the correct term, so as to get my thought across, clearly to him.
What is the opposite of a structural wall? Would it just be "non-structural wall?"
flipjarg is offline   Reply With Quote
Old 10-04-2010, 07:45 PM   #2
fabrk8r
fabrk8r's Avatar
I think all walls are structural, but some walls are load bearing, some walls are non-load bearing.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 10-04-2010, 07:58 PM   #3
DIY staff
Rewards Points: 7,174
Non load bearing wall are sometimes called 'partitions'--I'm not sure that that term is used correctly,however.
Old 10-04-2010, 08:15 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the common wall would be a demising wall.
as mike said; a non-load bearing wall is typically a partition wall.
The Following User Says Thank You to nap For This Useful Post:
unlvrebel (10-05-2010)
Old 10-04-2010, 08:18 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Then there are also "parting" walls.
XXX
Old 10-04-2010, 09:09 PM   #6
jlhaslip's Avatar
Rewards Points: 2,820
Opposite of a Structural wall would be a non-structural wall, but you may be confusing a structural wall with a load-bearing wall as per above.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-04-2010, 09:32 PM   #7
Wow, thanks for all the comments!
I was thinking of using "partition wall" but wasn't sure if it would be applicable. But after seeing the definitions, I am pretty sure it applies.
Thank you all! All of this information is going to come in handy for other letters I will be writing shortly.
Old 10-04-2010, 09:38 PM   #8
steveel's Avatar
Then there's "wall-it", used when it comes time to pay for materials and/or labor.
steveel is offline   Reply With Quote
Old 10-05-2010, 05:30 AM   #9
Chicago, IL
Michael Thomas's Avatar
"Common wall" is the correct term.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 10-07-2010, 07:50 AM   #10
Bill7 is offline   Reply With Quote
Old 10-07-2010, 08:00 AM   #11
Chicago, IL
But way, almost all "common walls" are also "load bearing" walls.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Concrete Wall Structural Strength geiser Building & Construction 2 03-11-2008 10:09 AM
