Tar Paper - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-11-2009, 12:40 PM   #1
tar paper
My son-in-law replaced the white cedar shingles on the side of my house. But neglected to put tar paper first. He put the shingles directly on the plywood. He said it would be fine. But I have doubts about this. Should it be redone?
62212 is offline   Reply With Quote
Old 09-11-2009, 01:11 PM   #2
Registered User
Termite's Avatar
Putting the shingles on the house without first putting up a moisture barrier such as felt paper is ill-advised. I believe I'd be re-doing it.
Old 09-12-2009, 12:16 PM   #3
Custom Cabinet Maker
I agree with KC that paper is very important, must be there. It serves as a moisture barrier to protect the sheathing/plywood. Shakes will shrink when dry and expand when wet, there is a possibility that rain can get behind them and therefore the reason for the paper. Also remember to put the paper on in the proper fashion,run UP from the bottom and overlap the lower sheet with the next higher one.
skymaster is offline   Reply With Quote
Old 09-12-2009, 04:22 PM   #4
tar paper
Thanks guys ,that is the answer I thought I was going to get.I'm a little short on money right now. How long do you think I can let this go before I fix it?
Old 09-12-2009, 05:31 PM   #5
Registered User
Termite's Avatar
How much rain do you think you'll get? Pretty hard to answer that question. Personally, I'd make it a priority. I also wouldn't let your son in law do it when you are ready to do it!
Old 09-12-2009, 05:52 PM   #6
Tar paper
We have had a lot of rain already. Don't worry my son-in-law won't be doing much around here anymore.
To remove or not to remove tar paper, that is the question Jeremy Hillary Boob, PhD Building & Construction 4 02-27-2011 08:34 PM
Help -Tar Paper on basement walls atm Building & Construction 9 09-28-2009 11:41 PM
Felt Paper and the Sun. Valley problems hartkem Roofing/Siding 1 07-22-2009 03:57 PM
contact paper removal scatterbrain Remodeling 2 07-06-2008 07:57 AM
