"tapping" Off One Sink To Add Another - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-09-2009, 09:46 PM   #1
Question
"tapping" off one sink to add another
I have a 1967 house and would like to replace the ancient, painted-to-death single vanity in the master bath. Rather than calling in a plumber to tear up the walls and solder in new plumbing, is it possible to "tap" off of the first sink and add a second sink to make a new double sink vanity? Is this a bad idea? Will it lower the water pressure on both sinks? Is it even possible to do?
demaris is offline   Reply With Quote
Old 11-10-2009, 04:24 AM   #2
Remodeling Contractor
yes you can tap off one and install the other with no issues.
Old 11-12-2009, 12:05 AM   #3
tapping of one sink to add another
Thanks Bob, any special concerns I should have about tying in the sink drain? Can all of the supplies be found at my local Home Depot? I've replaced single sinks without a problem, but never tried this.
Old 11-12-2009, 06:03 AM   #4
yes you can. They will have a drain kit that will connect the two sinks with a tee fitting. You will need to select the one with a DW tee if you also need a DW drain connection. Use sharkbite fittings if you need to extend the water lines. These just slide on to the copper and will join pex, copper or cpvc pipe to feed the water to the other tank.
Old 11-12-2009, 10:55 AM   #5
Tapping of one sink to add one
thanks Bob, you've made my day
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 07:07 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 08:43 AM
Help with construction of laundry sink VokinLoksar Plumbing 3 07-06-2008 06:42 PM
