Taping Order - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-09-2008, 09:50 PM   #1
taping order
when taping a house what order do u go in joints corners spotting screw, u know what I'm getting at any info would be great
rrisky is offline   Reply With Quote
Old 01-10-2008, 07:12 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Generally, it's not going to matter. We usually do them at the same time. However, that's a little tougher of a pace for the DIYer.
First Coat: Tape and one coat on the nails. As a DIYer, I would suggest that you apply your seam tapes first. That way, you are not going to be (wasting your time) coating nails that will end up getting coated by the tape and the tape's later skim coats.
Second Coat: Scrape down any ridges or lumps, coat the tape, apply coat on one side of corners, and coat the nails again.
Third Coat: Scrape down any ridges or lumps, finish coat the tape, apply coat onto the other side of corners, and coat the nails one last time.
After: Sand.
Last: Use a bright halogen light ot go around and touch-up any leftover imperfections.
Good Luck!
- Build Well -
Old 01-16-2008, 11:13 PM   #3
Thank you
Multiple projects - what order? dsr3 General DIY Discussions 10 07-11-2007 08:14 PM
What order 4 bst results shotdown Painting 6 06-27-2007 09:19 PM
siding, soffits, gutters - order? johnny331 Remodeling 1 06-15-2007 04:11 PM
Do I need a license in order to fix my tub (California) smalgin Plumbing 3 07-18-2006 05:11 PM
Exterior Paint Prep Order utdel Painting 2 06-24-2006 01:56 PM
