Tape On Walls - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 03:49 PM   #1
tape on walls
how to get tape of the wall
sharon ornelas is offline   Reply With Quote
Old 03-19-2011, 03:59 PM   #2
the Musigician
DangerMouse's Avatar
Imagine if you will, a roomful of people..... strangers you've never met.
You enter the room and say "how to get tape of the wall"?
Please try to remember we are people here trying to help other people, not machines.
Now, that being said, what type of tape, what wall, why is the tape there, how long has it been there and other details might help us help you.
DM
Old 03-19-2011, 08:44 PM   #3
Learning by Doing
Leah Frances's Avatar
DM
DM - what an apt analogy!
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-19-2011, 11:25 PM   #4
Rewards Points: 558
You peel it off silly...
epson is offline   Reply With Quote
Old 03-20-2011, 02:06 PM   #5
Been at it for 45 years
This Old Spouse's Avatar
Rewards Points: 79
Actually, I've found the best way is to get another piece of tape (best kind IMO is packing tape) and fold over the edge so you can grab it easily. Then put it over the tape already on the wall and burnish it with the edge of your fingernail or the edge of a spoon. The point is to completely cover the old tape with the new tape, then using the folded-over edge, peel away very carefully and it should come off.
I know this because the house we bought was apparently occupied by folks who had a lot of stuff taped to the walls, floors, ceilings, woodwork and windows. Six years later I'm still removing it.
This Old Spouse is offline   Reply With Quote
Old 03-21-2011, 07:23 AM   #6
60 grit paper on a belt sander.
screwy is offline   Reply With Quote
Old 03-21-2011, 07:42 AM   #7
Rewards Points: 79
Ah, yep, that'll cure a lot of things. Please stay away from my house.
Old 03-21-2011, 07:47 AM   #8
the Musigician
A hammer works just as well.....
....then..... after the sheetrock is replaced, mudded, primed and painted, do not put tape on the wall any more.
DM
Old 03-21-2011, 07:48 AM   #9
Learning Things Every Day
Jay 78's Avatar
One word: Sawzall.
Under Construction
Jay 78 is offline   Reply With Quote
Old 03-21-2011, 07:54 AM   #10
DIY staff
Rewards Points: 7,174
O.K.--Goof Off---(xylene) go buy a little can.
Now everyone--please resume the silliness.
Old 03-21-2011, 08:10 AM   #11
the Musigician
Now, if 'Goof Off' does not work, the next level would be contacting Warner Brothers/ACME Services.
However, this should be a last resort only for the most stubborn of tape.
DM
Old 03-21-2011, 08:23 AM   #12
DIY staff
We have an ACME clearance store near by in Toon Town,I'm saving up for a pair of rocket powered roller skates.----
Old 03-21-2011, 08:26 AM   #13
Seriously, could you steam it off? The heat should loosen the bond.
Old 03-21-2011, 08:32 AM   #14
DIY staff
I'll bet that would work. It depends on how many pieces of tape-
Steam could be slow.
Many years ago my kids "decorated' the living room with streamers---
I imagine kids are involved here,too.--
Old 03-21-2011, 08:35 AM   #15
the Musigician
Or run a hot iron over it quickly to heat the tape?
Then use a putty knife or chisel?
But who knows what the surface under the tape is? Semi-gloss paint? Flocked wallpaper?
We may never find out.....
DM
Tape Showing cougar01 Drywall & Plaster 3 03-09-2011 04:21 PM
Insulating poured concrete basement walls Dude Building & Construction 0 03-03-2010 12:24 PM
Insulate/air seal shared walls in townhome? RebornRenov Building & Construction 4 01-07-2010 09:50 AM
Paint pull-up!?!? with BM Aura Bath & Spa, GE Silicone II, and PM Green tape DIYatHome Painting 8 12-12-2009 03:52 AM
Blue tape peeling away the old wall paint drlsubaru Painting 9 05-13-2009 09:58 AM
