tape and float plywood
3K views 4 replies 4 participants last post by  RippySkippy
is it possible to tape and float primmed plywood as you would drywasll?
#5 ·
The short answer is yes you can. I've done it and for the right application it works well. I lined the landing of a stair well with plywood, and treated it like drywall and you couldn't tell the difference unless you tapped it or was a kid trying to kick a hole in it....
In a ceiling application...I'd use drywall, not plywood.
