Talking To Inspector?? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 11:05 PM   #1
Rewards Points: 150
Talking to inspector??
So i have a thread about finishing a mudroom but ths is sort of seperate.
Basically i want to finish a room that used to be a porch but is already sided roofed etc. has water and elctric already.
The water lines keep freezing because it gets so cold. So I HAVE to do something.
If I can without foundation issues I will just talk with inspector and do it all on the up and up and gain sq footage but if i cant i still need to insulate and rock this room.
So the inspector has agreed to meet with me about general question at which point I should be able to determine if the foundation will go... Can i do this without giving him info??
I dont want problems if i cant do it legit.
Could i still insulate and rock it and just disclose that the room is not living space if i sell?
Like i said i gotta do something because frozen water lines to the washer does go to well.
organick is offline   Reply With Quote
Old 12-10-2010, 07:44 AM   #2
Rewards Points: 6,652
If it is a mudroom, or all-season room, and there are water pipes in there I would insulate the space, and if needed, use heat tape on the pipes when they meet the cool air. Worst thing to do, is to have a frozen pipe burst.
Old 12-10-2010, 07:12 PM   #3
Rewards Points: 150
Yeah i know i gotta do something just trying to figure out if i screw myself by talking with inspector if the foundation for the room is insufficient for living space
Old 12-11-2010, 10:15 AM   #4
Are you going to be using it to live in?
Old 12-12-2010, 04:44 PM   #5
Rewards Points: 150
Its just a 8x12 laundry room. not living in it per se....I have a thread about those issues though.......
really just trying to figure out how to handle the inspector without screwing myself
Old 12-12-2010, 05:48 PM   #6
Easy way, keep your mouth shut, do not divulge anything to give them more to chew on, and when they get done, read over the inspection report, or have a real contractor go over it to know what needs to be corrected before the reinspection if there is one.
Old 12-12-2010, 07:43 PM   #7
Rewards Points: 150
hes not coming out yet.......i am meeting at his office and he has no info on my address etc....just getting general ideas from him but want to make sure I can have this meeting without divulging info about myself and house..........guess i'll just go for it
would just hate to finish the room and have issue when I sell
being a mudroom could i just disclose it as not up to code if need be at sale time?
Old 12-12-2010, 08:28 PM   #8
Really can't tell you. Personally if it was me, I would find out if plumbing and electrical inspections are needed (in my town, a homeowner can pretty much do anything they want with their home, only need permits when it comes to building a new garage, adding onto a home (ie pouring foundation, raising walls and a roof), tearing down a home). Nothing is needed for doing your own electric, plumbing, or finishing off a space (ie change porch into conditioned space).
Only thing I can tell you is, your AHJ is the only ones that can tell you what and why you need a permit for.
Old 12-13-2010, 07:37 AM   #9
Rewards Points: 276
To meet the immediate needs to prevent your pipes from freezing I would suggest self-regulating heat cable (not tape) and those foam insulation sleeves. It is cheap insurance against freezing until you can closed this area in and insulate it properly.
Jim F is offline   Reply With Quote
Old 12-13-2010, 03:22 PM   #10
Rewards Points: 5,336
Lenders will have issue with buildings with code violations and areas without C of O's. As in not issuing a mortgage to the potential buyers.
Ron
What the home inspector missed Michael Thomas Off Topic 21 11-07-2010 07:22 PM
Inspector says this isn't up to code gma2rjc Off Topic 8 04-23-2010 04:09 PM
Newbie with a Building Inspector problem Germain Remodeling 4 11-08-2009 06:33 PM
Exactly what is my City inspector DO when he inspects a replaced hot water tank? 73andsane General DIY Discussions 5 09-05-2008 07:46 AM
How is electrical inspector doing the inspection... KUIPORNG Electrical 2 08-15-2006 08:46 PM
