Take Glass Out Of Vinyl Window To Make Chicken Coop Window - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-30-2013, 07:21 PM   #1
Rewards Points: 12
Hello. I have some free vinyl windows (double pane) that I was thinking of taking apart to get the glass so I can make lighter, wooden sashes with grids for a chicken coop. Is this easy enough to do or is it not worth the hassle? Thanks.
igapo is offline   Reply With Quote
Old 03-30-2013, 07:30 PM   #2
joed's Avatar
Rewards Points: 13,718
I think I would try and use them with the vinyl frame or look for some older wooden windows that are being removed for new vinyl install.
The Following User Says Thank You to joed For This Useful Post:
joecaption (03-30-2013)
Old 03-30-2013, 07:42 PM   #3
Rewards Points: 14,306
Not worth the time and effort.
Old 03-30-2013, 07:48 PM   #4
Rewards Points: 12
Thanks. I was trying to remember what the panes looked like without sash. Doesn't seem like it is worth dissecting. Thanks.
Old 03-30-2013, 09:45 PM   #5
Rewards Points: 2,240
You can do it.
However, if you don't have experience -
you'll bust the glass.
I speak from experience.
Not worth it.
rossfingal
rossfingal is offline   Reply With Quote
Old 03-31-2013, 11:50 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,726
Ayuh,... The glass comes out, Really Easy,.... with a Hammer....
Old 04-01-2013, 10:17 AM   #7
For old wood windows you might want to check a local Restore
Mike in Arkansas is offline   Reply With Quote
Glass Block Window - Two Layers of Siding myowngc Building & Construction 1 12-23-2010 01:20 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Installing vent in glass block window jasoncw Building & Construction 6 09-27-2009 10:57 AM
Impact Windows & French Doors Matty16 Carpentry 6 06-22-2009 09:01 PM
Glass block window position?? justdon Remodeling 4 09-28-2008 06:29 AM
