Swimming Pool Gas Heater Repair - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-08-2009, 10:58 AM   #1
swimming pool gas heater repair
My gas heater fires up the burners ok but the water still comes out the same temp as it went in. Is there some kind of thermostat, like a car has, that is closed? How about a bypass valve?
alanmav is offline   Reply With Quote
Old 06-08-2009, 03:52 PM   #2
You may want to have it checked by a pro. The burners may not be firing at full capacity.
SKIP4661 is offline   Reply With Quote
Old 06-15-2009, 07:56 AM   #3
there may only be a 2 or 3 degree temp rise between in and out. Pool heaters have internal bypasses built in to keep the temp rise down to prevent condinsation from developing. Then of course you may have a real problem such as calcium build up it the tubes of the heat exchanger.
sninny is offline   Reply With Quote
swimming pool enclosure grendon Building & Construction 18 02-11-2015 10:30 PM
Wiring for swimming pool heater and salt system Scooby Electrical 1 06-08-2009 12:59 PM
Pool timer on an electric water heater...Yes or no? Gusaroo Plumbing 2 09-01-2008 09:13 AM
Swimming Pool Converted To Fish Pond ghall79 General DIY Discussions 6 05-23-2008 12:11 PM
