Sweaty Pipes In Basement While Washing Clothes - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 10:31 PM   #1
I moved into a new home, and it took us a while to hook up the washer and dryer. Well now I have been washing a lot to catch up on laundry, and we noticed that a pipe in the ceiling is sweating and dripping. What could be causing this and how do we fix it? Any suggestions would be appreciated.
Shona
shocanfixit is offline   Reply With Quote
Old 04-19-2011, 06:10 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
If you are running cold water through the line, you are chilling the pipe to below dew point for the amount of relative humidity present in the air. You can either insulate the pipe to keep the warmer moist air away from the cold pipe or run a dehumidifier to lower the relative humidity in the room.
Old 04-19-2011, 07:13 AM   #3
Rewards Points: 6,652
How warm is it in your home, and how cold is it outside?
Old 04-19-2011, 07:47 AM   #4
joed's Avatar
Rewards Points: 12,904
It is as simple as a cold pipe and humid air. Just like a glass full full of ice water in the summer. It sweats. If the humidity is high then you should install a dehumidifier in your basement to reduce it.
Old 04-19-2011, 12:02 PM   #5
It's pretty cold here in Michigan for late April, in fact it snowed yesterday.
Old 04-19-2011, 02:07 PM   #6
I know that it snowed up there yesterday, but does not state how warm your home is, and how cold it is outside.
Old 04-19-2011, 02:49 PM   #7
concretemasonry's Avatar
Rewards Points: 2,608
All you are probably looking at is the exterior air temperature and not the temperature inside the basement.
This time of the year, your cold water is about as cold as it will be.
Put foam on the cold water lines and forget about the dehumidifier unless you have other moisture problem that you see after you become familiar with what you now have.
Dick
concretemasonry is offline   Reply With Quote
Moving basement washer to first floor issues mazeroth Plumbing 2 02-05-2011 09:10 AM
plumbing a washing machine in basement Chris Chapple Plumbing 1 01-30-2011 12:18 PM
Hot and cold water pipes under basement floor? alondis Plumbing 13 06-28-2010 06:56 PM
Pipes exposed in basement bathroom jmanwaring Plumbing 2 06-13-2010 02:56 PM
Got new Washing machine - now I have water hammering in the pipes. What to do? J187 Plumbing 3 05-02-2008 03:07 PM
