Swanstone Shower Wall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-17-2010, 09:34 PM   #1
I had a bathroom Shower re modeled with Swanstone material. I need information on how to clean the walls. I can't use Powder cleaners because they leave scratches on the walls surface. What can I use to clean the surface of the wall and what materials can I use to do the cleaning, and get hard water build up off the wall without leaving marks or scratches.
David
folkersen1 is offline   Reply With Quote
Old 03-18-2010, 05:55 AM   #2
Go to their website for cleaning/care instructions.
Old 03-18-2010, 09:23 AM   #3
ccarlisle's Avatar
I agree; however to remove hard water salt deposits, a scouring cleanser wouldn't be needed anyway, so Ajax etc are out right from the start. You'll need to dissolve these marks away using a mild acidic product for showers. It'll say so on the label...they're usually foaming bubbles because the acid needs time to work.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 03-18-2010, 02:05 PM   #4
Ive always had luck with plain old vinegar
Tonglebeak is offline   Reply With Quote
Old 03-18-2010, 05:23 PM   #5
Sandstone bathroom wall
Try diluting a tablespoon of oxyclean in a quart of hot water pour in spray bottle and apply.........
skyla123 is offline   Reply With Quote
Old 03-18-2010, 06:09 PM   #6
I just finished one. swan corp has a 800# you can call for info
i used denatured alcohol during construction which they called for, worked really well. any solvent without a petroleum base if i remember right
insted of pulling the metal cap under the lid i punched a bunch of small holes in it like a salt shaker, easier to control the flow from can
The older I get the better I was
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Framing Shower Wall in Bathroom Justin LaRue Kitchen & Bath Remodeling 2 06-30-2009 10:34 PM
Wall attached soap dish in shower Italgrl Tiling, ceramics, marble 1 06-20-2009 07:36 PM
shower head pipe snap inside of wall? snosurfa7 Plumbing 3 06-06-2009 09:15 PM
Water seeped through tiles in shower, wall ruined, need help. doogie88 Building & Construction 39 10-07-2008 04:13 PM
