Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-17-2009, 01:17 PM   #1
Default Super glaze bar table finish
I am hoping someone can give me some suggestions before applying the Parks Super Glaze to finish a bar table I made.
For the table top to make it fit into an English style pub in my basement, I used a spray solution to secure English beer coasters to a table top. They are thicker than paper and overlap on the table top which obviously leaves some gaps between the paper coaster and the table. This leaves air pockets. I am afraid when I apply the Super Glaze it will create a large number of air bubbles and they could be unmanageable to remove since the glaze becomes unworkable in about 25 minutes and the air pockets are probably substantial.
My question is does anyone know of a coat of "something" I can apply first to seal the coasters to the table and eliminate air from escaping and ruining my Super Glaze finish?
I appreciate any help.
jlwiu1 is offline   Reply With Quote
Old 01-17-2009, 05:28 PM   #2
Building codes guy, Mod
thekctermite's Avatar
You might want to post your question at our sister site, www.woodworkingtalk.com
thekctermite is offline   Reply With Quote
Old 01-17-2009, 05:51 PM   #3
Master General ReEngineer
Ayuh,... I don't know that product in particular,... I Assume it's a tabletop epoxy resin,..??
If you're doing a tabletop with an Epoxy "tabletop" grade resin, you would use the resin to attach the coasters to the tabletop,...
More resin, more coasters, More resin, til you get it where you want it to be....Work the air out as you go...
If it's going to be pretty thick,.. Tape can be used to dam the resin long enough for it to Set,...
By doing the operation as a single pour casting,... it lessens the amount of sanding between operations...
Good Luck,...
Old 07-15-2009, 06:32 PM   #4
Default Works well
I have worked with superglaze on some art projects, and I can say that the one GREAT thing about it is that after the initial cure time (8 hours) you can apply you can apply subsequent coats without worry of seeing any delineation between coats. So If you are enclosing the tabletop in a frame and pouring into that, I would suggest teh following: 1-2-3 (If necessary) thin coats to allow the air bubbles to either flow out or get encapsulated under a coaster. Be SURE to have a heat gun, or at least a good hot hair dryer, as that is Imperative to release all of the bubbles. A trowel with small notched edges works great for spreading, and the heat gun will push the liquid around a little too. Be sure to mix throroughly to ensure a clear finish, and most importantly, between coats, Seal the pour area with something to keep all dust particles out, and inspect your surface before your next pour.
chrisvalentino is offline   Reply With Quote
Old 07-16-2009, 09:46 AM   #5
Thanks for the replay. I figured it out eventually.
I made a frame to surround the table so when I poured the coating it didn't all flow off leaving the edges of the coasters exposed.
Also, I wish I would have known about the heat gun. I used a fireplace lighter that worked pretty well but took constant attention for the first 30 minutes to control the air bubbles.
Table looks fantastic and is a great conversation piece with visitors.
More On This Topic
Hi, my name is Jenny Villagomez and on behalf of Expert Village, I'll be showing you how to make chile rellenos. Coating the chiles in flour and preping the oil. Lets coat our chiles in flour, spread some flour on a plate carefully. Place the chiles and... Read More »
Kids love bubbles. A spectacular trick that will entertain kids and grownups alike is enclosing a person in a soap bubble. It's a great kids party event. If you're fast with a camera, you can capture the trick for posterity. Read on to learn more. Read More »
How to Sear a Roast
How to Sear a Roast by Expert Village
Hi, this is Josiah Owen and today we are going to talk about making pot roast. At this point we are going to go ahead and pour about a 1/4 cup of olive oil in our pan. We are going to turn it up on medium, medium high. What we are going to do we are... Read More »
On behalf of Expert Village I'm Lizbeth Muller and today I will show you a Asian chicken dinner that is absolutely delicious. Okay we are at the stove now ready for the action, ready for the cooking. This is my favorite part. So I'm going to use this pan... Read More »
Chocolate is one of many people's guilty pleasures. There's nothing quite as satisfying as savoring a block of chocolate. Enjoying a chocolate bubble bath is a way to indulge in chocolate healthily. The aroma of chocolate fills the bathroom, releasing... Read More »
Finish table edge after pouring epoxy thepiedpiper Remodeling 3 11-17-2008 10:12 PM
Seal Peal and Stick Tiles? Echo1 Flooring 15 08-12-2008 08:59 PM
Best way to finish ruff barn-board for indoor table? BradG Painting 4 07-29-2008 01:26 AM
Best protective finish for old barn-board, used as table? BradG Painting 8 06-18-2008 01:30 PM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 10:47 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
