Super Annoyed - Contractor Mis-cut All The Prepared Railing Pieces. - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-27-2013, 10:21 PM   #16
Framing Contractor
Rewards Points: 112
Poorly planned, poorly executed, not acceptable by my standards.
sixeightten is offline   Reply With Quote
The Following 2 Users Say Thank You to sixeightten For This Useful Post:
CarpenterSFO (06-29-2013), CENTERLINE MV (06-29-2013)
Old 06-28-2013, 12:34 AM   #17
Rewards Points: 282
no carpenter would ever install railing like that....on day 1 you learn to count your posts and divide the distance for even spacing (adjusting to comply with code limits).
guy may be a "handyman" but is not a carpenter.
jcrack_corn is offline   Reply With Quote
Old 06-28-2013, 12:43 AM   #18
jproffer's Avatar
Rewards Points: 706
How are you supposed to "wrap your hand around/over" the top part of that railing?
If this is a rental, that would worry me.
jproffer is offline   Reply With Quote
Old 06-28-2013, 11:29 AM   #19
Rewards Points: 81
yep, that rail is not a graspable handrail. "not to code"
one cut is offline   Reply With Quote
Old 06-28-2013, 11:40 AM   #20
Dave88LX's Avatar
Rewards Points: 564
I'm "just a" DIY/homeowner, but if I understand the code correctly, the railing has to be continuous, spaced 1 1/2" form the wall, and extend up to but not beyond 1 foot from the top and bottom of the stairs, and turn into the wall, or, at least not be left floating open.
If only this house wasn't built by morons.
This just goes on to illustrate why although I take a lot longer to do things, I just do them myself.
Dave88LX is offline   Reply With Quote
Old 06-28-2013, 03:20 PM   #21
Framing Contractor
Rewards Points: 112
I own a very similar house. Your rail was not installed correctly. It should turn out something like this.
Super annoyed - contractor mis-cut all the prepared railing pieces.-2013-03-07-18.57.11.jpg   Super annoyed - contractor mis-cut all the prepared railing pieces.-2013-03-07-18.57.28.jpg
Old 06-28-2013, 09:54 PM   #22
Dave88LX's Avatar
Rewards Points: 564
Thanks for those pics. Do you have a shot dead on going straight up the railing? Do you have the width for a knee wall there?
On my setup, there is no space between the up- and -down stairs. The drywall face of the 'down' staircase is on the same vertical plane as the outside of the stringer of the 'up' staircase.
Old 06-29-2013, 11:17 AM   #23
Rewards Points: 81
Your rail should continue all the way to the top for it to be considered correct.
The Following 2 Users Say Thank You to one cut For This Useful Post:
Dave88LX (11-09-2013), operagost (07-16-2013)
Old 06-29-2013, 04:45 PM   #24
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
Don't worry, by the time the renters have lived there a while and their 6 kids have used the railing for a slide and to play superman off of and tobaggan down the steps, run their toy trucks into it, and then the furniture going up and down leaving dents and scratches... it will all blend in and no one will even notice.
RWolff is offline   Reply With Quote
Old 06-29-2013, 05:30 PM   #25
Pro
Rewards Points: 91
Agreed, but you did get what you paid for. And along with everyone else, that railing is not to code. It's as good as a sign saying "Fall down and sue me".
CarpenterSFO is offline   Reply With Quote
Old 07-01-2013, 07:45 PM   #26
AHH, SPANS!!!
Rewards Points: 1,166
in that situation to make a post work it needs to be located in from the wall which decreases usable stair width or run the rail up under the cut back in the wall with no post at the top and then another shorter hand rail mounted to the wall to reach from the cut back to the top of the stairs.
hand drive is offline   Reply With Quote
Old 07-02-2013, 09:12 AM   #27
custom user
Rewards Points: 150
It looks like cutting the rails too short was just his warm up act. If he's the boss, I'd hate to see their other work.
JasperST is offline   Reply With Quote
The Following User Says Thank You to JasperST For This Useful Post:
CarpenterSFO (07-02-2013)
Old 10-24-2013, 01:31 PM   #28
Dave88LX's Avatar
Rewards Points: 564
The contractor still has not cashed the check. Hell I told my wife to cancel it. I get so aggravated looking at this thing. I haven't fixed anything with it yet.
Old 10-24-2013, 03:35 PM   #29
Rewards Points: 2,634
When I did my rail, I jogged the handrail like this: (this is not my railing, just a photo I found online)
Super annoyed - contractor mis-cut all the prepared railing pieces.-staicase.jpg
SPS-1 is offline   Reply With Quote
How to fix broken step railing? robertr4836 Carpentry 2 04-18-2008 12:19 PM
