Sunroom/porch Insulation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-04-2006, 08:58 PM   #1
sunroom/porch insulation
Hi, I'm new here.
I'm currently renovating an enclosed porch/sunroom on an older home I purchased in December. Best guess, maybe circa 1930. My primary goals are to insulate (reduce hating costs) and convert it into a main entry hall. To date, this potentially lovely room on the front of the house has been used for storage.
The room, 11x8', is set on a stone foundation, separate from that of the house proper. It's only about 12" high and not completely enclosed. The rear wall (if there is one) abuts the house foundation. At the front, there is a 6' wide cement landing which has shifted away leaving about 1" gap along the top edge of the landing. The side edges of the landing are still overlapped by the stone walls. There are also a couple of places on the side walls where mortar has fallen away and will need repair.
How can I best DIY insulate this area. Money is a factor; I've got none
Any and all suggestions are welcome. Thanks.
glsblwr is offline   Reply With Quote
Old 09-04-2006, 10:17 PM   #2
Building inspector
inspects's Avatar
If there is no potential for moisture intrusion I would use fiberglass batts or styrofoam sheet insulation.
inspects is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Rigid insulation question Endeavor General DIY Discussions 2 07-17-2007 10:27 AM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 04:04 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
Insulation material reusable? KUIPORNG General DIY Discussions 4 06-19-2006 02:38 PM
