Sump Pump Issue - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-05-2012, 08:25 PM   #1
redheadedjoe's Avatar
Sump pump issue
Well, my drainage pipe has disconnected itself from the pump. I also think there may be some underlying issues as well but won't know until I figure out a way to get into it. The previous owner built a wall over the hole so I am unable to do anything but stick a flashlight and hand through the tiny hole. Any suggestions besides removing the wall?
redheadedjoe is offline   Reply With Quote
Old 08-05-2012, 08:26 PM   #2
I forgot to say that I am trying to remove the lid to troubleshoot more
Old 08-05-2012, 08:32 PM   #3
Rewards Points: 13,446
And how can we help when we sure can not see it from here.
Old 08-05-2012, 08:51 PM   #4
So you've got your hand in the tiny hole and are trying to remove the lid ? Is this correct?
What purpose does this wall serve. What do you mean a wall over the hole. Do you mean a platform on top of the hole.
Regardless, Its gotta go. Can you see how it would be a ridiculous thing in the way in the event of a flood
creeper is offline   Reply With Quote
Old 08-05-2012, 09:16 PM   #5
Well I figured you didn't need to see a wall placed on top of a sump pit. I'm not at the house currently. I do not want to remove the wall. Could I possibly just cut the lid into two pieces and remove the lid, then put them back afterwards? And any suggestions on cutting through the plastic lid (I don't have any electric saws or many tools in general). If I need to buy something please recommend a brand or type. Thanks
Old 08-05-2012, 09:41 PM   #6
The wall just breaks up the utility room from another room in the basement. It's got oak wood paneling and is only 2 years old so I would just hate to take it down.
Old 08-12-2012, 11:18 AM   #7
Rewards Points: 160
to cut the plastic matters on what type of lid and if you can get to it...if you dont want to remove the wall, can you modify it with an access panel?
hellothere123 is offline   Reply With Quote
Old 08-12-2012, 11:25 AM   #8
Rewards Points: 6,652
If it was me, I would redo the wall, due to access is needed to the sump. That would mean deconstructiong it, so that you can put in an access panel.
As for that Oak paneling, it can be cut for the access hole, then place framing members back inside so that the panel can be reattached with hinges and a magnetic catch to hold it closed, vs using screws to secure.
I would not cut the sump lid in two, due to if it is the type to be secured in place, not just the cheap garbage can type lids, it was done that way on purpose by the manufactur of the product.
Take some pictures and post showing what you are dealing with.
Old 09-01-2012, 04:40 PM   #9
Bombastic Idiot
notmrjohn's Avatar
How you gonna get the pump out if/when you need to work on it?
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Sump pump back up DennyF Plumbing 4 02-17-2012 01:58 PM
understanding the numbers on a sump pump and which one to buy ksimpson Plumbing 0 09-09-2011 07:51 AM
Sump pump runs all the time....help? Chris Leach General DIY Discussions 9 07-14-2011 07:00 PM
sump pump water lower than normal???? fabian Building & Construction 18 12-05-2009 05:26 AM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 08:37 PM
