Sulfur Smell In Bedroom - But No Gas Leak? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-05-2013, 11:14 PM   #1
Rewards Points: 85
This has happened a few times over the past year and a half. Our bedroom smells like sulfur. We had the gas company come on emergency calls a couple times to make sure there were no gas leaks, even though it smelled like gas. They confirmed that there wasn't any gas leak. The closest gas line is about 15 feet away in the kitchen, but it doesn't smell like gas in there or anywhere else but in the bedroom. What else could be causing this sulfur smell?
Chris Sweeney is offline   Reply With Quote
Old 08-06-2013, 12:02 AM   #2
If you have a bathroom next to the bedroom, could be that sewer gas is coming from in there. Any renos done in the area just before the smells started?
VIPlumber is offline   Reply With Quote
Old 08-06-2013, 07:08 AM   #3
Rewards Points: 12,802
How old is this house?
Any drywall work been done in the past 13 years?
http://chinesedrywallcomplaintcenter...ndications.htm
Old 08-06-2013, 08:39 AM   #4
Rewards Points: 85
True, there is another bedroom between my [gas-smelling] bedroom and the bathroom, and that other bedroom doesn't smell, nor does the bathroom itself. The only reno done was that bathroom - a full gut - when we first moved in nearly two years ago.
The only drywall work that has been done was in that bathroom reno I mentioned above.
Old 08-06-2013, 09:06 AM   #5
Rewards Points: 6,652
Yep, someone put a hole into a vent line, or screwed up the toilet on the closet flange. Time to start cutting into some drywall, and yanking that toilet.
Old 08-06-2013, 09:19 AM   #6
Rewards Points: 85
Could this be, even though the smell has occurred only about 5 times over the past 19 months?
Old 08-06-2013, 11:44 AM   #7
Too Short? Cut it Again!
Sounds silly and simple but get up on the roof and make sure nothing is nesting in your roof vents! Put new caps on if you find anything after you sweep out bird and squirrel nests.
And once, I had a terrible sulfur smell in a bedroom that finally got traced to sour potting soil for a plant that was not draining.
Old 08-06-2013, 01:14 PM   #8
Yes, especially more during the Summer months, when drains dry out in slabs.
The Internet is not going to solve your problem, you are actually going to have to physically look for the problem. That means pulling the toilet to make sure that the Wax ring on the Closet flange was put in place, also pulling drywall on the wall, where the vent goes from the sink to the stack, and from the stack at the floor to the ceiling, to make sure whoever re-did the bath, did not put a hole into the piping, or worse, cut a big chunk out of it, and have it open in the wall.
Old 08-06-2013, 01:25 PM   #9
Rewards Points: 85
Thanks, I appreciate everyone's responses and willingness to help!
Let's say the wax ring is not providing a proper seal for the toilet. Why wouldn't I be smelling those sewer gases anywhere else in the house, i.e. in the bathroom itself, in other rooms closer to the bathroom than the room in question, etc.?
Old 08-06-2013, 01:47 PM   #10
A lot of variables. Such as is the door always closed on the bath, do you run a outside venting kitchen fan, are you always running the a/c while home and away, house closed up while gone, what is the temp of the home while away and gone, etc..
The wax ring is there to not only keep the smell from Sewer gasses from coming back out around the base, but also to not allow water to seep, when flushing the toilet.
Old 08-06-2013, 02:09 PM   #11
Haverhill Trade 1965
Have you noticed if it is a windy day, still day, rainy day, when it smells? Simplest thing would be a downdraft. just ad length to the vent stack. You said gas line, what about the exhaust from the gas? How far is it from the window?
Duckweather is offline   Reply With Quote
The Following User Says Thank You to Duckweather For This Useful Post:
joecaption (08-06-2013)
Can't figure out a smell in my room dariusld General DIY Discussions 7 09-28-2012 11:46 PM
Musty smell in wall outlet in bedroom and arouns windowsill in bathroom tbsnook Building & Construction 2 04-17-2012 11:33 AM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 08:26 PM
Mold smell in AC houndog HVAC 4 06-03-2010 07:27 PM
Roof leak around my chimney - update GlennAble Roofing/Siding 3 11-05-2009 07:24 PM
