Suggestions On Removing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-11-2011, 08:31 AM   #1
Rewards Points: 156
Suggestions on removing
I have 2 stumps to grind, problem is, as you can see in the picture, one has a steel pole going through it.
I was going to chop up around it with a chainsaw to see what I can do, unless someone else has a better suggestion.
Branden is offline   Reply With Quote
Old 04-11-2011, 08:39 AM   #2
Not so new
12penny's Avatar
Rewards Points: 520
...looks to me like theres no other choice.
...or maybe dig around the ball, chop the roots and pull it out.
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
Branden (04-11-2011)
Old 04-11-2011, 08:40 AM   #3
the Musigician
DangerMouse's Avatar
That's how I'd go about it. Carefully trim away until you can yank the pole out.
Plan on a few hours work on this one! *Good luck!*
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
Old 04-11-2011, 08:49 AM   #4
Not so new
12penny's Avatar
Rewards Points: 520
...and hope that post doesnt have 150# of concrete on the end.
Old 04-11-2011, 08:54 AM   #5
Rewards Points: 156
I'm hoping there isn't any concrete involved. I think the pole was put in to help support the tree when it was just planted and never taken out. It was actually a lot taller but I was able to cut a section out when taking down the tree. It sort of bowed out of the tree then back into it.
I was also thinking about getting it as low as I can and seeing if I can get a tree guy to use some old grinding teeth on his stump grinder to chew it up. Not sure if anyone would go for that or if it would work though.
Old 04-11-2011, 08:59 AM   #6
Not so new
12penny's Avatar
Rewards Points: 520
...you're going to have a hard time finding a guy with a stump grinder that will be willing to grind the post along with the stump.
...put on your gloves and put a little sweat into it. With a chain saw you should be able to make quik work of it.
Old 04-11-2011, 12:35 PM   #7
Rewards Points: 160
Backhoe.
cgoll is offline   Reply With Quote
Old 04-11-2011, 02:23 PM   #8
Rewards Points: 1,016
I would not expend my energy to remove it until I would talk to guys with grinders and see what they say. I am sure it's not the first time they have encountered metal in a stump - here you probably have an advantage, because I bet usually they probably don't know about it until they hit it...
Old 04-11-2011, 02:32 PM   #9
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
Blast it out.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-11-2011, 03:37 PM   #10
Handyman
Rewards Points: 512
Originally Posted by rusty baker View Post
Blast it out.
Yeah! and don't forget the YouTube videos!
canadaclub is offline   Reply With Quote
Old 04-11-2011, 03:47 PM   #11
Rewards Points: 24
I don't know if this is applicable in your situation, but I have seen quite a few surveyor's stakes with trees grown around them.
Old 04-11-2011, 05:01 PM   #12
waterman1971's Avatar
Rewards Points: 150
I would cut down just enough to get a pipe wrench on it. Maybe you will get lucky and get it to turn. Wonder if you could put some dry ice down there to shrink it while turning and pulling on it.
waterman1971 is offline   Reply With Quote
Old 04-11-2011, 05:04 PM   #13
kwikfishron's Avatar
Rewards Points: 86
Good saw, sharp chain, shovel, and a Sawzall it could be gone and cleaned before lunch.
kwikfishron is online now   Reply With Quote
Old 04-11-2011, 05:16 PM   #14
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
I agree w/ the pipe wrench comment! Since it was used to support the tree when the tree was very little I would just cross my fingers and hope concrete wasn't used at the time.
CoconutPete is offline   Reply With Quote
Old 04-11-2011, 06:51 PM   #15
Owner
LateralConcepts's Avatar
Hard to tell from the picture... What's the diameter of the tree and the pipe?
I think it would make a cool seat or table.
The pipe could be used as an umbrella holder.
If you don't want it, I bet if you cut it off as closely to the ground as possible, you could sell it on Craigslist or Ebay
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Suggestions for my Kitchen ktm General DIY Discussions 7 04-08-2011 09:13 AM
Kitchen Cabinet Suggestions + General Kitchen Suggestions ffmariners Interior Decorating 3 08-16-2010 03:41 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
Removing a Fireplace - suggestions? BigFloyd Building & Construction 1 08-03-2006 06:01 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 10:28 AM
