Suggestions On Covering Exterior Concrete Foundation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-25-2010, 09:10 AM   #1
Question
Suggestions on covering exterior concrete foundation
I would like cover this foundation wall with something more visually appealing:
I've been told by a stucco company that they would cut the water barrier at grade level and stucco up from there. I've also been told by a veneer company that stucco would crack. If I go with stucco, would it need a metal lathe, or could it be applied directly to the concrete? By the way, I live in Georgia if that matters.
Thanks,
Drew
dhysong is offline   Reply With Quote
Old 04-25-2010, 10:03 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
that waterproofing mebrane should have a termination bar attached to the top edge and sealed so water can't get behind it after its cut
Tom Struble is offline   Reply With Quote
Old 04-25-2010, 10:21 AM   #3
Will stucco be ok
If I cut the membrane and install a termination bar, can the stucco then be applied directly to the foundation wall, or does it need a metal lathe overlayed?
Thanks,
Drew
Old 04-25-2010, 11:00 AM   #4
I think I'd add another timber or 2 & bring the dirt level up in that corner
Make a corner planter to help fight the erosion
Keep at least 8" from dirt to siding
Old 04-27-2010, 03:36 PM   #5
Prince George, BC
I like Dave's idea, but I'd take it 2 steps further. Terrace it up and route your eavestrough downspout under the whole works using perforated big-O.
PS - my apologies for making a mess of your photo
PS - I would still seal up the top edge of the membrane and then hit the rest with foundation waterproofing tar.
MisterPG is offline   Reply With Quote
Old 04-27-2010, 07:46 PM   #6
Stone veneer?
This looks like a good place to use some stone veneer. I'm looking into Eldorado Stone and Owens-Corning for something similar. CH
chubbyhubby is offline   Reply With Quote
Tags
foundation , stucco
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 08:34 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
Water pooling next to house foundation pictures - help suggestions Steelmesh Building & Construction 8 07-03-2009 10:05 AM
How to add footing and foundation to existing foundation? ptcamaro Building & Construction 6 06-22-2009 10:22 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
