Subwoofer Pre-out Wiring - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-24-2014, 05:35 PM   #1
Rewards Points: 145
Subwoofer Pre-out wiring
I was redoing electrical in some walls so I had my electrician snake speaker wire for 5.1. I'm having trouble getting my subwoofer to power.
- My receiver has 2 sub preouts, pre manual same output from each
- My sub has 2 line level inputs and 1 LFE input.
- I ran normal speaker wire to a terminal.
I tried splicing a cheap RCA connector to the wire to hook up one terminal to LFE but it won't power. I've verified the speaker wire in the wall end to end works with a regular speaker. I've run a mono RCA cable from LFE To the receiver and the sub works.
Is it possible to connect 1 sub preout to LFE over normal speaker wire?? Any solutions?
Thanks!
kjmass1 is offline   Reply With Quote
Old 05-24-2014, 08:46 PM   #2
Msradell's Avatar
Rewards Points: 278
I think you're going to have to go to a forum where there are more audiophiles. Almost everyone here could tell you how to wire it but most of us aren't familiar with the needs of the equipment that you are talking about.
Msradell is offline   Reply With Quote
Old 05-25-2014, 06:46 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 188
There is a Home theater forum on the main page, try it.
Old 05-25-2014, 10:53 AM   #4
Try this:
http://www.avsforum.com/t/1533091/is...ight-to-an-amp
northernlite is offline   Reply With Quote
Old 05-26-2014, 04:31 PM   #5
Rewards Points: 4,218
For starters you need shielded cable. Regular speaker wire will pick up too much interference on low level inputs.
Second, was the sub properly plugged into an outlet?
Bob Sanders is online now   Reply With Quote
Old 05-26-2014, 04:32 PM   #6
Originally Posted by northernlite View Post
AVS is great for electronics. Been a member for years... highly recommend it.
Old 05-26-2014, 04:48 PM   #7
Rewards Points: 145
So theoretically you can't convert speaker wire to coax/mono rca ?
So I either need to run a coax, or get a sub that accepts speaker level inputs ?
Old 05-26-2014, 04:52 PM   #8
Rewards Points: 744
sounds like something is wrong with your splice.
Seattle2k is offline   Reply With Quote
Old 05-26-2014, 09:15 PM   #9
I didn't say that. You SHOULD be getting something. Wire is wire. That's why I asked if you actually made sure you plugged the sub in and it's getting power. Are you sure the sub is plugged into a wall out let and is getting power?
Old 05-26-2014, 09:44 PM   #10
Rewards Points: 145
Yes correct. I ran an RCA cord to the LFE just to be sure and it worked fine. I have pretty thick 14 ga wire so I'm having a hard time finding an RCA plug adaptor to hook in to. I may just try and fish the coax and be done with it.
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
