Subfloors - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-26-2009, 12:14 PM   #1
After getting may replies to my different questions (thank you all by the way), I started to measure my basement for the sub floor and design it.
I realized that the sliding door sits less than an inch above the concrete floor. Probably enough room to put down some padding or very thin foam and slide the laminate flooring under the rim of the sliding door. (I am will be close)
Question is: Is this acceptable? Nearly everyone states to put a sub floor down with insulation. Can it be insulated another way to get the same or near same affect or will I have to suffer with flooring right on the concrete. Someone mentioned under floor radiant heat, but that will certainly break the little budget I have.
Any other ideas? Thank you again.
Retirement is offline   Reply With Quote
Old 02-26-2009, 01:10 PM   #2
Remodeling Contractor
A concrete floor will transfer water moisture into the basement from the soil by capillary action. If salts are not present you can seal the concrete with an epoxy coating. This will act as a capillary break and equalize the pressure through the concrete stopping water transfer. Extruded polystyrene should be 3/4" or less to allow the surface to still breathe. After this you should be fine with your laminate flooring. Should not be tucking under the threshold anyway, since you need a 1/4" space around the perimeter of the room for expansion.
Old 02-26-2009, 01:37 PM   #3
You seem to alwasy answer my questions. Thank you for your response.
Removing Subfloor(s?) Bacchusbill Flooring 12 09-25-2008 05:34 AM
Wavy Subfloors and Flooring Choices jasonb Flooring 14 12-20-2007 08:22 AM
Basement finishing smallcrpt Remodeling 18 11-12-2007 05:27 AM
have osb subfloors that squeak on 3 story duplex runbikeengr Flooring 12 04-19-2007 01:33 AM
