Sub-floor Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-15-2010, 09:50 PM   #1
Post
sub-floor question
We are installing a sub-floor and wanted to know what type of product we should use to help prevent the extreme hollow sound. Any suggestions would be greatly appreciated!
missemma001 is offline   Reply With Quote
Old 02-15-2010, 10:40 PM   #2
jlhaslip's Avatar
Rewards Points: 1,502
what flooring are you placing over top of it?
is is blocked or braced underneath?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-16-2010, 12:16 AM   #3
We are using engineered wood flooring with the moisture barrier underneath. One of my friends suggested using insulation...
Old 02-16-2010, 12:44 AM   #4
jlhaslip's Avatar
yes, there are some really good underlays that deaden the sound.
and adding insulation between the joists would help. you need access to the basement to add that.
Old 02-16-2010, 12:56 PM   #5
this is tough.....i put down "composite snap-together wood flooring system with the melamine infused paper top" in a basement over the required vapor retarder sheeting. the system was floating and even with a 4" concrete slab under it, the floating system feels hollow and fake.
i won't do a floating system ever again but would consider the 3/8" engineered in a nail down application over plywood sub-floor. or the 1/2" and definitely the 5/8" if they were nailed down. i like a floor that feels solid when it looks solid. maybe it's just a personal hangup i have.
minidriver8 is offline   Reply With Quote
