Sub Floor Plywood Vs OSB - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-03-2016, 08:58 PM   #1
Solutions (handyman)
Rewards Points: 362
sub floor Plywood vs OSB
I will be doing a job replacing a damaged subfloor. Question is, is there much benefit in using Fir Plywood versus OSB? Both are 3/4" t&g. Up here, the fir plywood is almost double the price of OSB. Is there a reason for this? Advice is appreciated.
Mark Harvey is offline   Reply With Quote
Old 02-03-2016, 11:45 PM   #2
Msradell's Avatar
Rewards Points: 84
Overall plywood will make the floor stronger and will be more water resistant if that's an issue. If this is already an enclosed structure and you're just replacing the subfloor water may not be an issue. If it's a 2 layer for the lower layer should be plywood, the upper layer it doesn't matter quite so much. If it's a one layer floor it definitely needs to be plywood.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 02-04-2016, 09:50 AM   #3
Rewards Points: 12,808
Just not true.
Advantech subflooring is stronger, more stable, far more moisture resistant, 50 year warranty.
http://www.huberwood.com/advantech/performance/strength
Old 02-04-2016, 11:30 AM   #4
http://www.buildgp.com/dryply-plywood
http://www.buildgp.com/plytanium-plywood-sheathing
ron45 is offline   Reply With Quote
Old 02-04-2016, 11:40 AM   #5
WhatRnsdownhill's Avatar
Rewards Points: 2,220
what does your building dept have for code, certain ares will not allow osb...find out before you put the wrong stuff down..
WhatRnsdownhill is offline   Reply With Quote
Old 02-04-2016, 10:51 PM   #6
Msradell's Avatar
Rewards Points: 84
Originally Posted by joecaption View Post
Just not true.
I certainly agree that if you use Advantech you will have great results but the OP ask about OSB which is something boldly different.
Old 02-05-2016, 12:23 AM   #7
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 844
Avoid OSB, whatever the code says. It's not flat enough for a good floor surface, and it will swell if it gets wet. It's fine for a lot of applications, but subflooring isn't one of them.
Thunder Chicken is offline   Reply With Quote
