Stymied by window leakage problem.
Sorry I didn't see a specific window forum...
I have owned a condo on the bottom floor of a two story unit for about a year now. Coming up on monsoon season here in Arizona, and for the second year in a row I have a leak in all four major windows of my condo. The leak is coming through the wall, inside, and destroying the plaster and whatnot of the window frame (not to mention getting water everywhere). The water is clearly coming from the condo above, which is being rented out although the owner and I are trying to address the problem. I am not that familiar with home improvements etc like I am with fixing cars, and as such do not have much knowledge to go on. The person who is also the HOA president read that there was a possible blockage of the seepage holes in his windows causing water to build up and therefore leak down through the wall and into my condo's window frames. Well yesterday we cleaned out his windows and the holes and using a hose sprayed them down with water, and it still leaked. We have eliminated the cause as a problem with the roofing of sorts (the unit is a stucco, flat roof, flat sides, etc) because we did not spray water that high, only at his windows. The only thing I can possibly think of is the windows more or less sit flush with the outside of the building. There are parts of my window where you can sort of see the wall and it's direct connection to the window, and so water could seep through that connection (I would assume) and I assume his windows are the same way. (Not sure if that makes sense) As such the windows have all be caulked on the outside where the window meets the stucco but to no avail. I'm not sure what to do because the guy is VERY nice, but I'm sick of this problem. It is either his or the HOA's responsibility to fix the problem, depending on what the problem actually is (if it's outside it's the HOA's, if it's his actual windows, then it's his problem). I am getting close to wanting to sue as this is an ongoing problem for about a year (fortunately it doesn't rain much here) but I don't feel I would have much of a case because he can prove that he is at least making an effort to fix the problem... Any advice on either situation would be greatly appreciated. |
Post some pictures of the outside of the second floor windows close ups or zoom in on them.
Hi from the heat! Monsoon won't come soon enough and surely won't last long enough.
Replace the windows. For some reason a lot of these condos, apartments, and stucco/styro boxes are built with leaky windows. I just moved out of a 60's brick duplex with "newer" windows and they leaked no matter what I did. I even filled the tracks with silicone inside and out - we never opened them anyway because of thieves, noise, and air pollution. |
That's easy to say when it's your money but I can't force this guy to get new windows...
This link is on part of my site. Not trying to sell you anything, but the page is full of details for vinyl/windows and Hardie/windows.
Some variation thereof will be the answer. http://www.albertsroofing.com/Window%20Flashing.htm |
| All times are GMT -4. The time now is 07:47 AM. |
