Stupid Working In Attic Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-15-2009, 11:40 AM   #1
Stupid Working in Attic Question
I feel like this is a really stupid question, but I can't find an answer anywhere...
I plan to add a vent to my bathroom which will require work in the attic. What is the minimum recommened lumber to use to cross over the joists? I figure I would use 12" lumber. Just wondering if 1x12 is adequate or 2x12? I hate to have to buy and keep lifting and positioning anything heavier than I have to up there as I make the trek across...
ande3171 is offline   Reply With Quote
Old 03-15-2009, 12:27 PM   #2
Not so new
12penny's Avatar
Rewards Points: 520
ande....1/2" plywood would be okay. If you're big or joists are 24"oc then you might want to go to 3/4". No reason to buy dimensional lumber.
12penny is offline   Reply With Quote
Old 03-15-2009, 01:17 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Agreed! Just make sure you position it right, or it will flip up on you.
jbfan is online now   Reply With Quote
Old 03-16-2009, 05:45 AM   #4
The others seem to understand, but not sure what you mean by a vent. If you mean a bath exhaust fan, what you suggest is considerable overkill. Those vent fans normally use 4" round duct, whch can be rigid or insulated flexible.
Old 03-16-2009, 07:58 AM   #5
I think he is saying he needs to climb across his attic rafters and wants to put some lumber down perpendicular to the ceiling rafters to walk across. In that case you would be fine with either plywood or a 2x12, even a 2x10 but I wouldnt buy 1xanything for walking planks.
Occam's Razor - The simplest answer is probably the correct one.
JCAHILL4 is offline   Reply With Quote
Old 03-16-2009, 09:04 AM   #6
Just do not vent into the attic, the vent needs to exhaust outside
Old 03-16-2009, 11:36 AM   #7
Thanks for the help guys. I was thinking 2x12's might be better as I would probably have a future use for them once I'm done, but a couple sheets of plywood should get me there.
Yes, I plan to vent out the soffit.
Old 03-16-2009, 04:37 PM   #8
Don't know it all, yet!
Had an instructor once who was giving the usual speech about no such thing as a stupid question in class. "If you're wondering it, someone else probably is also"- you know the story.
I liked his final point though. Stupid questions are a lot easier to fix than stupid mistakes.
So ask away.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 04-16-2009, 10:45 AM   #9
I am planning to run some coax and network cables in the attic
so this "walking in the attic" thread is interesting. (I had the builder
put in a 2" PVC "conduit" that runs from the basement to the
attic in this 2 story house.
I'm in southern Ontario so the attic has blown in insulation. It is
blown-in insulation and thick enough to cover the joists.
I was planning to lay planks perpendicular to the joists to walk on.
For me, plywood sheets are not really an option as the opening into
the attic is only roughly 2ft x 2ft.
The planks would squish the insulation under it.
Does anyone know if blown-in insulation will re-fluff once the planks
are removed?
sunjwd is offline   Reply With Quote
Old 04-16-2009, 11:01 AM   #10
Registered User
Rewards Points: 526
Yes, it does if you use a lawn rake, or similar. When you blow it in, it is compressed for shipment. Be sure to fire foam the tube, if a fire started in the basement, it would very quickly spread to the attic, with that fuse between floors. Be safe, GBAR
Old 04-16-2009, 11:04 AM   #11
jbfan's Avatar
Rewards Points: 650
are removed?
Not in any attic I have worked in.
Old 04-16-2009, 12:56 PM   #12
Rewards Points: 1,548
If there is not that much insulation above the joists and you plan to use the planking over and over, then you might consider attaching stand-offs to the joists and install the planking on top of that. Use sections of 2x3 or 2x4 (depending on height needed) on edge. Toenail to the joists or drill long pilot holes to countersink the nails or screws way down to reach through to the joist.
Old 04-17-2009, 12:07 AM   #13
I was afraid the answer was going to be something like that. Thatīs what I was thinking. :-)
A lot of hassle to run some wire but good safety. Night mares of stepping thru some ceiling drywall.
a stupid question about tub spouts farmerde Plumbing 6 01-15-2009 06:20 PM
Attic fan in Attic access door kubotaart HVAC 10 09-17-2008 12:55 PM
Embarrassingly stupid question about latex paint joeyboy Painting 7 08-20-2007 09:25 PM
Switching from light socket to plug - stupid question CGofMP Electrical 5 03-25-2005 09:48 PM
