Studs / Mullion In Between Door And Sidelights - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-09-2013, 01:32 PM   #1
Rewards Points: 37
Studs / mullion in between door and sidelights
When I originally spec'd out a door it was a 6' french door with 24" sidelights on each side of it. It was going to be shipped in 3 pieces and then mulled together in a single opening. Due to a couple of issues, it would be much better if I could put these in 3 separate openings, will 3.5" mullion between the door and each sidelight. My question is, is this going to look weird? I don't see any installations like this so I can't really grasp how it's going to look.
The way I figure, it's going to mean around 5" of gap in between the door and the sidelight (3.5" for the mullion, about .75" lost to the opening, and about .75" due to whatever I trim it with). Any opinions on how this would look? Thanks!
SoxFan44 is offline   Reply With Quote
Old 07-09-2013, 07:24 PM   #2
DIY staff
Rewards Points: 7,174
It will look kind of industrial and might look out of proportion. Could you explain the design change? If it is structural perhaps someone here could offer a solution.
Old 07-09-2013, 07:37 PM   #3
Rewards Points: 37
Yea it's structural. Our engineer came back and said we need a w6x25 beam. But there are issues furring out our 2x4 walls to 6" on on one side so I wanted to try to get us down to a 5" or even a 4" beam. hence the studs between the door and sidelights.
