Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-23-2006, 09:32 AM   #1
Stud mounting on Aluminum studs
I ran into this recently while hanging small cabinets, shelves, etc. I suspect there are aluminum channel studs behind the walls as opposed to wood 2x4's. Is there a preferred method to screwing into these aluminum studs for maximum holding strength?
DK75 is offline   Reply With Quote
Old 02-14-2006, 02:01 PM   #2
when dealing with metal studs you should try to avoid smooth connections as they can slide out. also some p[eople prefer to use adhesives instead of a fastener.
a1steelbuildings is offline   Reply With Quote
Old 02-17-2006, 09:24 AM   #3
Darylh's Avatar
I would just use Metal screws and pre drill
Darylh is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-11-2006 12:10 AM
How to line up trusses with studs aero_ub Carpentry 5 04-24-2006 04:48 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
