-   -   Stud mounting on Aluminum studs (http://www.diychatroom.com/f2/stud-mounting-aluminum-studs-1710/)
DK75 01-23-2006 09:32 AM
I ran into this recently while hanging small cabinets, shelves, etc. I suspect there are aluminum channel studs behind the walls as opposed to wood 2x4's. Is there a preferred method to screwing into these aluminum studs for maximum holding strength?
a1steelbuildings 02-14-2006 02:01 PM
when dealing with metal studs you should try to avoid smooth connections as they can slide out. also some p[eople prefer to use adhesives instead of a fastener.
Darylh 02-17-2006 09:24 AM
I would just use Metal screws and pre drill
