Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-16-2009, 12:27 PM   #1
Stuck Screw
This problem has been giving me a pain for a while now, so I figured I would ask for some help.
I have a long screw that is held in place by a nut, the nut, is inside a steel box, there is no way of getting to it, the screw goes in, and is supposed to fasten via the nut, instead when I try to remove the screw, the nut spins at the same time because its placed improperly, so the screw is stuck.
Any ideas on how to remove the screw? I cant really go at it with an arsenal of tools, because the head of the screw is perfectly level with the surface it holds in place too.
IceTreay is offline   Reply With Quote
Old 03-16-2009, 12:49 PM   #2
Stuck Screw
you might try grinding the head of your bolt ( I am assuming it is a bolt if it has a nut attached to it) once the head is ground off to the diameter of the shaft of the bolt, you should be able to push it in the hole. Do not know off the top of my head how you would re-install a bolt. What is this steel box with bolt on. Is it part of vehicle or ??? More info might give possible solution.
Pics would help alot
fixrite is offline   Reply With Quote
Old 03-16-2009, 02:14 PM   #3
Stuck Screw
Are you going to want to reinstall the bolt? Do you care if the nut and part of the bolt drop into the box and stay there forever?
Old 03-16-2009, 02:41 PM   #4
Stuck Screw
http://www.crossedupoffroad.com/cata...ges/JamNut.png
This is the nut inside the steet box, in the odd little diagram, its highlighted as green.
The red highlighted area is in fact a long Philips head screw.
I've considered cutting the head off, but because the nut spins with the screw, I cant get it out enough, the head of the screw is flush with the surface (in the diagram, the red is flush with the horizontal line)
Old 03-16-2009, 02:57 PM   #5
Stuck Screw
Can you get a thin bladed putty knife between the two parts? You could slightly pry them apart and the friction between the nut and this metal box may be enough to keep it from spinning.
47_47 is offline   Reply With Quote
Old 03-16-2009, 03:08 PM   #6
Stuck Screw
I had actually tried that, I used a precision screwdriver to try to lift it, but its not enough friction, I also tried putting it with pliers, still nothing
Old 03-16-2009, 03:19 PM   #7
Stuck Screw
Did you turn the head of the machine screw by hand? Try a cordless drill with the pry action?
What exactly are you taking apart? Can you drill a hole in this metal box big enough to get in needle nose pliers or wedge the nut with a screwdriver?
Old 03-16-2009, 04:55 PM   #8
Stuck Screw
Wedge the bolt head up with some needle nose pliers (not held tight), then hit it with a high speed screwdriver.
It ain't Rocket science unless you are building rockets
Tscarborough is offline   Reply With Quote
Old 03-16-2009, 05:07 PM   #9
Stuck Screw
If all else fails I would use a glue to glue the head in its opening and then drill it out once the glue had cured.
More On This Topic
How to Remove Lug Nuts
How to Remove Lug Nuts by Expert Village
Hi. My name is Nate McCullough, on behalf of Expert Village. In these clips, we're going to talk about the proper way to inspect, remove, replace, and maintenance your vehicle's shock absorbers. In this clip, we're going to talk about the service... Read More »
Okay, now you can take this out. As you can see these were very dry, see that edge there it's suppose to be nice and smooth. Now a way to get these off, you basically just want to work them back and forth. These are really stuck on there, just work it... Read More »
Learn how to remove guitar strings to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
How to Remove Motor Mounts
How to Remove Motor Mounts by Expert Village
In this clip, we're going to talk about the proper service procedure for removing and reinstalling a motor mount. In this step, we're going to talk about removal of the motor mount bolt itself and removal of the mount from the body of the vehicle. As you... Read More »
Hi, My name is Nate McCullough on behalf of Expert Village. In the following clips we're going to talk about the correct procedure for replacing your upper and lower ball joints on a 2 wheel drive, full size vehicle. In this clip we're going to talk... Read More »
Sheared head on Tapcon screw - how to remove? mkuether Remodeling 9 12-04-2008 09:18 PM
Screw and plug 5/4" PTP decking Klaus Building & Construction 3 06-10-2008 08:01 AM
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 32 02-09-2007 10:22 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
