Stuck Nut On Gas Pipe - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-21-2016, 11:40 PM   #1
Rewards Points: 4
Stuck nut on gas pipe
Trying to remove a nut on a pipe that is part of my gas fireplace. This nut will not budge at all. While trying to remove the nut I noticed I was actually twisting the pipe from behind the wall.
1) Is it common for these nuts to be welded or permanently attached to the pipe?
2) In lieu of removing the nut should I/can I buy an adapter? Trying to put on h-burner with 1/2 inch male thread.
3) Should I be concerned that I twisted the lead pipe from behind wall? (Probably 1/4 turn, realized it and tightened it back(
Steve
Stuck nut on gas pipe-image-1144000746.jpg   Stuck nut on gas pipe-image-3523772311.jpg   Stuck nut on gas pipe-image-919773414.jpg
huskersteve is offline   Reply With Quote
Old 01-21-2016, 11:44 PM   #2
griz's Avatar
Rewards Points: 570
cut it off
twisted pipe could be an issue
griz is offline   Reply With Quote
Old 01-21-2016, 11:51 PM   #3
Rewards Points: 4
Griz...thanks for your reply. Cut the pipe where and what issues may be there? I'm trying to set up my gas fireplace.
Old 01-22-2016, 06:13 AM   #4
An old Tradesmen
Rewards Points: 6,116
Thats not a nut. Its an adaper/fitting, MIP to flare. You need to use a pipe wrench as a hold back wrench on the pipe, and then turn the adapter off of the pipe.
Find the other end of the pipe, remove pipe from fitting, clean threads, and turn pipe back into fitting. Use a hold back wrench when ever working with pipes.
The Following User Says Thank You to beenthere For This Useful Post:
oh'mike (01-22-2016)
Old 01-22-2016, 06:58 AM   #5
Rewards Points: 438
If Tef tape had been used during assembly none of this seemingly one welded to the other would have happened. But you still need a back up pipe wrench to make sure the fitting you need to turn lefty loosey is the only one that turns in this instance.
SeniorSitizen is offline   Reply With Quote
Old 01-22-2016, 07:42 AM   #6
Rewards Points: 4
Thanks for the replies. It sounds like the fitting, agree not nut but couldn't think of term, should be able to be removed. I should use a pipe wrench to hold back pipe from moving and not the fitting. If that doesn't work how do I get to the other end of the pipe like one suggested?
Old 01-22-2016, 08:11 AM   #7
Low Slope Roofing
Rewards Points: 114
The black pipe is most likely not lead, if it turned it probably has an elbow behind the firebox somewhere and that's what turned. I'd look in to that so you don't have a gas leak behind the firebox.
Like others have said, use a pipe wrench to hold the black pipe and another one to remove the fitting. Make sure to seal all of the connections and double check there is no leaks when you are done.
1985gt is offline   Reply With Quote
Old 01-22-2016, 08:19 AM   #8
Rewards Points: 4
Is it easy to get behind the firebox? This is becoming more complicated than I thought when I bought my new burner !
Old 01-22-2016, 08:23 AM   #9
Low Slope Roofing
Rewards Points: 114
I really couldn't tell you. Does the line run to the outside of the house or drop down through a wall to the basement. It looks like that was a woodburner at one time that has been converted over to gas.
Old 01-22-2016, 08:43 AM   #10
Rewards Points: 4
It was originally gas then converted to wood, now back to gas. Heading to work now, but I think I can get back there. Last question for today. What about the "putty" stuff that is around the pipe when it enters fireplace? Is that easy to put back on there? Looks like it seals the pipe when it enters the firebox.
Old 01-22-2016, 08:51 AM   #11
WhatRnsdownhill's Avatar
Rewards Points: 2,220
ok, so you have been burning wood in the fireplace with the gas pipe in the middle of the flames? if so dont even think about using that piece of pipe, and how much junk, ash is down the pipe, plus the wood burning heat probably hurt the integrity of the pipe...remove that piece and install a new one with a new adapter for the flex line...the putty is just cement, there should be a sleeve for the gas line going through concrete, one pipe size larger and then with high heat silicone you can seal it in the sleeve..
WhatRnsdownhill is offline   Reply With Quote
Old 01-22-2016, 09:13 AM   #12
Rewards Points: 4
Sounds good. There was a flex line that I just removed before the picture, but agree with the heat it's probably safer if I just remove the entire line. I have to get to work now but I'll take some pictures of the panel before removing it. Hoping it is super easy. More to come.
Old 01-22-2016, 09:16 AM   #13
there should be a shutoff valve in the fire box off to the side when the pipe first enters...and another in the basement or down line from the unit..
How to Estimate Water Flow Rate in Copper Pipe arskiracer Plumbing 12 04-15-2013 09:50 PM
Cutting and gluing PVC pipe to washer steve3847 Plumbing 8 10-03-2012 09:00 AM
stuck compression fitting on copper pipe John Malarkey Plumbing 2 05-10-2011 09:23 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 05:01 PM
