Struggling To Finish Porch Project - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-08-2010, 12:31 PM   #1
Rewards Points: 492
struggling to finish porch project
As I attempt to complete this project, I've hit some road blocks as I attempt to finish the interior of the enclosed porch.
http://flic.kr/p/8qtokz
1. I've put rigid foam insulation in the gap. i then added some spackle (container said interior/exterior but for exterior app. will need to be weatherproofed, painted). still in the process of sanding spackle. i have to make a choice about what to do next. up to this point i've assumed i would add some molding. some have suggested using 1 X4 flat stock. i have made a template of the siding but have yet to buy the wood or make any cuts.
2. one of my larger errors is evident here. on the right side of the door the wood is bowed at the top. not sure how i missed this.
http://tinyurl.com/24w8zy9
1. have to figure out what to do with each corner on this side.
2. should I just paint the exposed wood?
3. a closer view: http://tinyurl.com/2dpusog
http://tinyurl.com/2ashhp7
1. this corner was no more than an inch wide, so I used some caulk saver and caulk.
http://tinyurl.com/29jshyu
1. i put a piece of untreated 1 X3 here temporarily to see how it looked. it doesn't cover all of the wood. when i get the right fit, maybe i will stain everything?
thanks for all of your help. i can see the light at the end of tunnel and i want to be sure that i finish this project in a quality way, having spent so much time and energy on it.
joetab24 is offline   Reply With Quote
Old 08-08-2010, 04:42 PM   #2
Rewards Points: 266
It looks like you've got a prehung screen door without any frame- header, king studs, jack studs etc. A framing guy can explain it better than I can so I won't attempt it. As it is it won't last long even if you do get it squared up.
Jim F is offline   Reply With Quote
Old 08-08-2010, 05:05 PM   #3
kwikfishron's Avatar
Rewards Points: 194
At this point all you can do (as mentioned before) is scribe in the trim. Buy a couple extra boards or rip some plywood strips to practice on and make a pattern it may take a couple of tries to get it right.
Get it close then caulk is your friend.
kwikfishron is offline   Reply With Quote
Old 08-08-2010, 05:14 PM   #4
Rewards Points: 492
@Jim,
thanks for the reply. I guess it's just the camera shot, but I have everything but the cripples. the pic above was before i added the header. i'm noticing there is no bow in the right 2 X4.
Old 08-08-2010, 06:11 PM   #5
Rewards Points: 266
That picture looks much clearer. It looked like you had a 1x framed prehung door in you flikr pics. I see they are 2x's now and not prehung.
Old 08-08-2010, 09:27 PM   #6
Rewards Points: 5,336
If you want the door to operate long term, install a door frame around the unit and and add space around the frame to compensate for the exterior wood movement.
Ron
Old 08-11-2010, 07:44 AM   #7
Rewards Points: 492
Ron thanks for the feedback
"If you want the door to operate long term, install a door frame around the unit and and add space around the frame to compensate for the exterior wood movement.
Ron"
But I am not sure what I would add? Would I have to take all of this down?
Old 08-11-2010, 03:14 PM   #8
Ron"
You would need to move one side of the rough framing away from the door, 2 " so the door frame could go in. I'd move the right side and add to both the jack studs as they're too low. Even if you left this in place and put a header in, it would actually sit on the screen on the right side.
Ron
Old 08-11-2010, 04:23 PM   #9
Rewards Points: 492
@Ron,
regarding the jack studs being too low, you are right. I had to shim them so the door would clear.
I somehow missed the part in the door's installation instructions that discussed building a frame for the door. Guess I should have known this.
The door seems to be stable but if it won't last I am going to have to start over. Won't it look odd or asymmetrical if I move the right side over 2"?
Old 08-11-2010, 04:50 PM   #10
@Ron,
Move the rough opening the way you want. Remove the whole shabang and reframe it. Your porch, your choice. What ever makes you happy, Joe.
Ron
Old 08-11-2010, 08:12 PM   #11
Rewards Points: 266
They typically offer interior and exterior doors pre-hung. That is, they already come on a hinged frame that you plumb and square with shims within your door frame- what you have pictured there that still needs a header. I would think they would sell screen doors pre-hung in a frame as well. It would make your installation much easier since the pre-hung frame is already square to the door from the factory.
Where porch roof meets wood siding Trish99 Roofing/Siding 14 07-16-2009 09:31 AM
Load Bearing Exterior wall however it has an overhanging porch rhoton1 Building & Construction 2 03-16-2009 07:19 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 09:44 AM
No Permit for my Porch and Deck jokiddjr Building & Construction 15 06-13-2007 11:34 AM
